Rear mechs with a c...
[Closed] Rear mechs with a clutch...leave on all the time?
Whats the score with the clutch rear mechs, XT in particular, should it be left switched on all the time or will this do any harm? Does it make shifting any harder?
Posted : 06/04/2014 10:28 pm
You have to put the clutch in to change gear.
Posted : 06/04/2014 10:29 pm
The only time I switch mine off is to remove the wheel.
Posted : 06/04/2014 10:30 pm
I turn it off when stored to relieve the spring, but when riding, it's on all the time.
Posted : 06/04/2014 10:35 pm
All of the time for me too.
Posted : 06/04/2014 10:38 pm
Mine (SRAM) has no off, can't see the point in not using it. Another bit of good progress.
Posted : 07/04/2014 12:07 am
Used mine for the first time today. Tried it without the clutch on for the first road section, and then with it on for the rest of the ride. No real noticeable difference in shifting.
Was also running a wide/narrow works ring for the first time today......witchcraft I tell 'ee! Nary a dropped ring all afternoon, on some proper rooty/rocky trails too.
Posted : 07/04/2014 1:09 am
 JoeG
Only turn it off to remove or replace the wheel.
Posted : 07/04/2014 3:51 am
My XT mech is always left on, and after almost a year of use there’s still plenty of tension in the switch.
Posted : 07/04/2014 9:07 am
