raw fnish alloy fra...
[Closed] raw fnish alloy frame (turner) - cleaning, polishing and wear patches?
the finish is pretty industrial, so does it need polishing?
somebody mentioned baby oil rubbed over the frame, but i'm not sure if that's a good idea or not?
also... wear patches... any point? obviously, there is no paint to wear through, but will they protect from wearing through the alloy itself?
cheers
Posted : 16/05/2011 10:11 pm
stick a picture up then and I might tell you what to do! ๐Ÿ˜•
Posted : 16/05/2011 10:13 pm
http://www.singletrackworld.com/forum/topic/the-flux-has-landed-new-build-turner-flux
fair few on there for you
Posted : 16/05/2011 10:17 pm
You certainly need wear patches because the Aluminium will still rub away in time.
I can't quite make out if there are scratches in the frame from the picture, but if there are, you will need to cut back with a finer abrasive paper. Probably p1200 to p1500 will help to remove these. Then you need to buy a cutting compound/polish to further remove those finer scratches and buff back to a shiny finish. Lots of work but you could use a polisher/machine to make it easier.
Good luck!
Posted : 16/05/2011 10:33 pm
