Raceface Narrow Wid...
[Closed] Raceface Narrow Wide Users - General Question
30t narrow wide ring
Non clutch slx rear mech
No chainguide
No chainslap and never dropped the chain
Posted : 08/01/2014 9:53 am
Nothing bodgy about running a 10-speed mech on 9-speed, with the right conversion anyway. Works like it was designed to. Nice side-effect of Shimano ripping off SRAM's ideas 😉
Posted : 08/01/2014 10:07 am
@MadBillMcMad
Do let me know, will be interested to see how you get on, cheers.
Posted : 08/01/2014 1:32 pm
I've got a clutch mech and a N/W sitting in the house ready to go on my Five. I have been running a Bashguard for years and have kind of got used to well just bashing into things.
So who is running a bash with there N/W and what did you go for ?
I was thinking of something like this.
[url= http://superstar.tibolts.co.uk/product_info.php?cPath=56&products_id=818 ]SS Slider[/url]
Posted : 08/01/2014 1:46 pm
Not convinced a bash serves much of a purpose when there's only one ring.
Posted : 08/01/2014 1:53 pm
I will be running XT M780 with a RF NW chainring I'm going to give it a go without any chain device, but wont be able to test it fully until Saturday, I will let you know how it goes..
Posted : 08/01/2014 1:56 pm
honourablegeorge - Member
Cheers 🙂
Do you reckon the chain gives enough protection ?
Posted : 08/01/2014 2:00 pm
Not sure, pre taco days of LG1's = lots of broken chainrings on the DH bike.
In fact the second time out on my current bike, got way too loose in a corner, kicked up a big rock & bent the XX1 front ring.
I had an old SRS+ that you can lose the lower half of, so you get the top guide & run that with a bashring. The chunks taken out of the bashring indicate it's doing something 🙂
Posted : 08/01/2014 2:04 pm
tested last night @endurokid
1x9 with a RaceFace 30T on to an SLX Double chainset.
The 30T just, just fits with no grinding needed.
decided to leave the bashguard off, but kept the front mech on as a chain retention device. No idea if it was needed but I had no problems at all.
We did not do any monster climbs & only rode 20km as it was piss wet,
but all in all quite happy. Trying to get up Winter Hill could be a challenge though.
Posted : 09/01/2014 10:03 am
I've got a bash on mine (30t Wolftooth on XT cranks). There's not a lot of meat on a 30t 104bcd ring so I'm happy to have a wee bit of extra protection for my £50 investment.
Posted : 09/01/2014 10:27 am
I ditched a bash ring last year when I went to an open style guide and had no issues. However on new years eve, I ballsed up a rocky section in the Peaks and ground my chain against a rock. It seems ok.
If I was regularly riding rocky tech stuff, I'd get a bash especially if your bike has a low BB.
Other than that I've been really happy with my set up so far.
Posted : 09/01/2014 10:32 am
I've been running a RF NW for a few months now with Zee clutch mech and no chain guide or bash. All good news, shifts really well and no dropped chains even in rocky stuff. I started with a Zee shifter and then upgraded to a Saint but not sure I'd bother again if I had to pay full price. Just using a cheap SRAM 10 speed chain.
Only slight concern is not having a bash having got used to one over several years but so far no damage to chain or ring.
Posted : 09/01/2014 11:02 am
Whats longevity like with these? Riding in south wales drive train gets eaten pretty quickly.
How long before you lose the retention of the wide narrow teeth?
Posted : 09/01/2014 11:15 am
I've been using my narrow wide ring since late August and have have ridden is some pretty gtotty conditions and it seems to be holding up well. I live in the Midlands and it's pretty sandy, so when it gets wet it creates a lovely grinding paste.
I have no idea how long it will last really.
Posted : 09/01/2014 11:34 am
Had no chain loss issues on mine at all (Zee clutch) and am pretty happy with the gearing (32 11/36) for my riding which does not really involve any massive uphill slogs.
Only thing I have noticed is that in gritty mud (for example Swinley has a sandy grinding paste in the wet) it does get quite noisy, not sure if anyone else has noticed this?
Posted : 09/01/2014 12:18 pm
Yes. Particularly in the lower gears (bigger cogs) at the back. I ascribe this to:
1/ Chainline is optimised for the middle of the cassette, and if anything a bit offset to the outer part (when looked at closely I reckon chain is straightest on mine in about cog 6)
2/ the tolerance is that much tighter with the wide teeth on the chainring, so there isn't as much space for the chain to exit the chainring at an angle and it therefore rubs more on the teeth as it exits.
3/ Being least optimised in Cogs 1 and 2 is when I get most noise, but also is when I'm going slowest and therefore hear more (less clattering / wind noise to cover it up)
Posted : 09/01/2014 12:43 pm
Along the lines of what I was thinking, more material in contact = greater potential for noise. I can certainly live with it when taking into account all the other benefits (and the general lack of chainslap).
Posted : 09/01/2014 1:36 pm
I've set my bike up with a 30 NW and 11-36 and a clutch mech. Not had a chance to try it yet but am hoping that I've got a low enough gear for when I'm goosed going up a massive hill at the end of an eight hour ride (30-36 is quite close to 22-28 which is the lowest gear I've ever used!).
Am keeping an old 44 ring on as a bash guard and for riding long flat sections (will just lift chain over by hand).
Posted : 09/01/2014 8:46 pm
What are the recommendations for chain length when swapping to 1x10? I've just taken off my 38/26 double and put on a 32t up front (36 rear) - do I need to lose some links from the chain to get more tension? (RF n/w, xtr clutch)
Posted : 11/01/2014 5:51 pm
currently using m785 cranks would like to use a 32t narrow wide ring but would like to use a bashguard, anyone know what's compatible?
Posted : 11/01/2014 5:58 pm
localhero94 - Member
I only had to remove one link, going from a triple chain set and long cage rear mech to a 32t and short cage SRAM XO clutch mech, both with a 11:36.
I've had zero problems on the two rides I've done with this setup so far.
Posted : 11/01/2014 6:00 pm
Bought the E13 one to avoid RACEINYOURFACE gfx...
Posted : 11/01/2014 6:14 pm
Any one running a bashguard on their xt m785 cranks with the narrow wide chainring?
Posted : 11/01/2014 10:50 pm
Been running a Works 34t (made in England!) since May - very effective. Have a bashring too (running Zee cranks) which may help keep the chain on but I don't think I really need it.
Posted : 11/01/2014 11:17 pm
Finally got my NW one and pimped it up with a KMC gold chain, need to remove a link or two but will see how it runs Sunday, looking forward to it!!
Posted : 16/01/2014 10:06 pm
The chain on my Rune is quite slack, but there is a fair amount of growth under compression so I left it to be safe. I get a little bit of chain slap when it gets really bumpy but still not lost a chain yet. Not even when I went over the bars at the weekend.
There is a but of wear to the ring now. All the really wet gritty rides have scored the teeth, but it's still working well so I'm a happy bunny.
Posted : 16/01/2014 10:45 pm
I was wondering how the rings would hold up after a few months use in a British winter!
I intend to change my chain every few months so may as well do the same with the ring.
Posted : 16/01/2014 11:06 pm
Mines not dropping chains etc so I'll leave it until it does.
In all fairness it's not worn any more than my ali Hope chain ring did. I'm guessing that the scoring is because the chain sits tighter on the teeth so any grit (and there's lots of that at the moment) has no where to go.
Posted : 18/01/2014 9:59 pm
I've been rotating three KMC X10L gold chains for the last year - really slows the wear to the cassette and chainring and jockey wheels. With the quick link pliers and no chain guide they're fast to change - hang up all three and whichever is shortest goes back on. I think three is overkill, will be alternative between two on the new bike.
Posted : 19/01/2014 12:22 am
First ride today and I'm mega impressed, not even a hint that I might loose the chain, I thought my dropper was the best thing on my bike but this set up blew me away!!!!
Think I'll order another KMC X10L for the tool box!!
Posted : 19/01/2014 4:48 pm
Page 2 / 2
