Am considering a tubeless set up, using stans etc. Only thing is I use the same bike every day for work and then on weekends, increasing the pressure for the trip to work and then running the tyres much softer for weekends and evening rides. Is this likely to be problematical running stans tubeless? Am I going to be squirting latex letting the pressure down every couple of days or drying out the latex quicker than normal?
cant see a problem, if i let air out i make sure valve is at the top so only a little bit leaks out.
Yeah, just make sure valve is at the top. Also don't pump higher then 50ish psi.
Hmmmm. Cheers.
Am just weighing up the benefit of running tubeless or not. (it's new wheel time) stans rims on pro 2s are out of stock everywhere so do I wait for them or buy some non tubeless now. Incedentally it's not as if I suffer flats often so that benefit isn't an issue.
Ho hum .. What to do?
