Quick question on r...
[Closed] Quick question on road brakes, as I'm a bit confused......
[#1552251]
....here goes - Whats the difference between a front and rear caliper on a road bike? I have the opportunity to get a bargain Ultegra brake but I can only get [b]rear[/b] brakes - will one fit on the front of my bike too? I have carbon forks on my Specialized Secteur (2010).
Cheers everyone!
Posted : 28/04/2010 9:06 am
Longer bolt that goes through bridge ?
Posted : 28/04/2010 9:07 am
 JoB
the rear has a [i]shorter[/i] mounting bolt, and some rear brakes are made mechanically less powerful than the front to prevent skidding
Posted : 28/04/2010 9:12 am
"to prevent skidding"
they take all the fun out of life...
Posted : 28/04/2010 9:13 am
the rear has a shorter mounting bolt,
Could I buy a new bolt to put it on the front?
That seems like a spectacularly dumb idea, but I can see it happening...
Posted : 28/04/2010 9:14 am
No campag always did it (well since dual pivot brakes were invented), shimano brought it in on the current* DA.
Single pivot brakes weigh less (1 combined pivot & bolt Vs 2 and a lot more aluminium), so why not shed 50g from the calliper?
It's a bit like mountianbikes, very few people run the same rotors front and back, XC racers run 160/140, trail bikes 180/160, dh bikes 200/180.
*pun intended
Posted : 28/04/2010 9:20 am
 JoB
"[i]Could I buy a new bolt to put it on the front?[/i]"
i'm sure you could, but knowing how much Mr Shimano doesn't like people taking his components apart too much.....
"[i]That seems like a spectacularly dumb idea, but I can see it happening... [/i]"
maybe i should rephrase it by saying some people found the new dual-pivot rear brakes too powerful so they made them less efficient again
Posted : 28/04/2010 9:23 am
I run 200mm on the back of my rig for max skiddage.
Posted : 28/04/2010 9:29 am
The allen key fitting type nut (that fits into the counterbore hole in the back of the forks) that screws onto the stud/mounting bolt, can be bought separately in different lengths. Some companies (Sram) supply 3 or 4 lengths of nut with their brakes. Your LBS should have a selection.
Posted : 28/04/2010 9:33 am
U R awsum wikkid, nuf respek.
Posted : 28/04/2010 9:36 am
