Query re: old Fox V...
[Closed] Query re: old Fox Vanilla Rear Shock
4 Users
I have an old Vanilla Rear shock that I wish to bring back into use and want to know if it is in good order. It is one of the old ones without a piggyback. I have removed the spring and compressed the damper rod and it slowly pushes back out but with a slight squelch at the end. No fluid or bubbles but just a squelch, in truth it may not be a liquid squelch but perhaps dried out seals? I'll lube up the damper rod and try again.
Does anyone have any tips on deciding if this needs attention or not? I want to replace my air shock with the coil spring because the air shock needs continually needs service attention. Any help appreciated.
Posted : 15/04/2011 6:06 pm
 jonk
They are nitrogen charged so if you can find someone to charge it just change the oil and it will be fine again.I had mine charged at a local MX shop. Mojo can also service older shocks too
Posted : 15/04/2011 6:29 pm
Try mick gardner racing 01226 240099. they deal with ohlins shock and are doing a nitrogen recharge for my noleen shock, so they probably can do yours. cost about £10-£15
Posted : 15/04/2011 6:39 pm
Aaaaaagggghhhhh - and now I have just snapped the rebound knob! It was a bit stiff and I got the pliers on it.... now it's very loose. Full service mehinks, by someone that knows what they are doing.
Posted : 16/04/2011 9:30 pm
http://www.locotuning.co.uk/
Posted : 16/04/2011 9:48 pm
