PSA - Shimano Deore...
[Closed] PSA - Shimano Deore Brakes BR-M486 reduced to £14.99 on CRC
not sure if this is just the caliper or the caliper, lever and hose...seems like a good bargain though...
[url= http://http://www.chainreactioncycles.com/Models.aspx?ModelID=87334 ]linky[/url]
Posted : 07/02/2013 12:32 pm
In the description:
[i]Great value and dependable brake [b]calliper[/b] gives you plenty of power when you require it. For use with mineral oil which is non-corrosive and less hazardous than conventional hydraulic fluid. Shim-less mounting bracket allows for quickinstallation and set up. Compatible with post mount or international standard forks when used with adapters. [b]To be used in conjunction with Shimano hydraulic brake levers[/b][/i]
Posted : 07/02/2013 12:40 pm
 cp
it's the complete brake inc. lever. done to death on another thread a little while ago.
Posted : 07/02/2013 12:43 pm
It's the full brake, [url= http://singletrackworld.com/forum/topic/psa-cheap-brakes-at-crc ]See here..[/url]
Mine came with a 1500 rear hose and a 700 front, and a rear 160 adapter..
PSA - fail... 🙁
Posted : 07/02/2013 12:45 pm
 cp
worth the reminder though - they are a bargain!
As on previous PSA;
Got mine, swapped the levers without bother, Rear hose was long enough for my Missus 15" frame, front was too short for her 100mm fork though so I ended up swapping the front for an older Deore brake off of my SS which has a longer hose.
Overall it was a net win but be prepared to change a hose or two (Still a bargain even if you do have to swap a hose IMO)...
Surprized they're still flogging them, might get another pair for spares...
Posted : 07/02/2013 12:59 pm
Got my front brake through, as said my lever was the wrong way round but if you buy the pair you can swap them over! 🙂
Posted : 07/02/2013 7:21 pm
word of warning. Love the brakes. But i swapped my hoses over and gave them a proper outing the other day. Although I thought they were fine they deffo need a re-bleed. Not a problem as I have new hoses to go on anyway. I should add that I didn't top up the resovour either which would probably help.
Posted : 12/02/2013 12:33 am
nice reminder, keep up the good work;-)
Posted : 12/02/2013 10:10 am
They have gone up in price to £25 each now!
Posted : 12/02/2013 4:38 pm
Doh! That's just happened in the last hour or so....was poised to hit the buy button.
Posted : 12/02/2013 4:48 pm
I had some in the cart too..! I was going to buy a set for my other bike as I was impressed with the first set I had.
Posted : 12/02/2013 4:50 pm
