PSA: Fox RP23 215mm...
[Closed] PSA: Fox RP23 215mm x 63mm £135 at CRC
6 Users
A bit specific, but a stand-out from their component sale. Fox RP23 high volume in 215mm x 63mm size, using code CM10 is £135.32 (no bushes). By comparison Mojo charge £111 + £4.95 postage for an RP23 service.
Posted : 07/05/2014 3:20 pm
 LoCo
You may also want to factor in a retune, good price though.
Our full services on RP23s are £80 plus postage too 😉
Posted : 07/05/2014 3:22 pm
I'm sticking with my Ti-springed CCDB 😉
Posted : 07/05/2014 4:21 pm
Mine was ****ed when it arrived
Posted : 07/05/2014 4:38 pm
 LoCo
How's it working now Rob?
Posted : 07/05/2014 4:42 pm
Very tempted here to get one and chuck it over to you ...Decisions decisions... 😉
Thanks for the oil Si..
Sill running the dhx5 you did on my spicy and it is really is rather good. 😀
Posted : 07/05/2014 5:22 pm
Loco, very wheezy still, generally noisy
Posted : 07/05/2014 5:24 pm
 LoCo
Pop it down to us for a check over Rob J.
Great, cheers Rob H 😀
Posted : 07/05/2014 5:37 pm
 hora
Lots of people will order this purely as its a 'deal'. Illness?
Saying this if a kashima rp23 in any size pops up. Im in!
Posted : 07/05/2014 6:10 pm
Simon, will do in two weeks mate
Posted : 07/05/2014 6:14 pm
 LoCo
No probs Rob.
Hora, It's a good deal even factoring a tune in, we've had a lot for retuning and mounting hardware.
To be fair I think Rob got some money back from CRC for the fault.
Even when not used from new a shock can be charge with several hundred Psi of nirtrogen so the seals are under constant pressure so leak s can happen sometimes, quite often customers have left a bike for 6 months and find that it has air leaks as the seals have sat and dryed and hardened due to the leak of movement and lubrication.
Posted : 07/05/2014 6:15 pm
simon - will it need booking in again? whats the cost?
Posted : 07/05/2014 7:48 pm
 LoCo
Pop it down and we'll have a look to see what the issue is.
Posted : 07/05/2014 7:49 pm
 hora
Loco I mean peeps will buy the shock not because they need one just because its a deal.
BTW can you Kashima upgrade a standard rp23?
Posted : 07/05/2014 8:18 pm
yes
Posted : 07/05/2014 8:33 pm
Loco, mine still blows through loads of travel when climbing, a little noisey but can put up with that.
Posted : 07/05/2014 8:38 pm
Loco I mean peeps will buy the shock because its actually the right size for their bike and will stop them snapping rear mechs every 20 minutes due to excessive chain growth from running a too-short shock
FTFY
Posted : 07/05/2014 10:29 pm
