Positioning of a ne...
[Closed] Positioning of a new Works Components OVAL chainring (where the flat bits go!)
Hi all, just bought the above in SRAM direct mount flavour for my XO cranks.
I can't work out where I should be putting the 'flats' on the ring. I'm thinking flat should be at the top when my cranks are horizontal.
Any info appreciated!
Posted : 20/12/2015 11:07 am
No idea about the sram one but the shimano one has a little raised "tooth" on the inside of the ring that lines up with the crank arm
Posted : 20/12/2015 11:11 am
Highest effective ratio during the highest power part of your stroke.
Posted : 20/12/2015 11:14 am
direct mount
Do you even have a choice?
Posted : 20/12/2015 11:18 am
[url=
link here[/url]
Posted : 20/12/2015 11:24 am
I am not sure if I have a choice Buccaneer. I'm just about to get out and have a go at fitting now.
I just wanted as much info as possible before I started!
The video is very helpful- cheers all
Posted : 20/12/2015 11:39 am
Hope it's gone well. I think your direct mount ring is held on the crank by three bolts but they are not evenly spaced so you can only fit the ring in one position.
Posted : 20/12/2015 12:18 pm
That makes sense. Cheers buddy
Posted : 20/12/2015 1:01 pm
They will only go one way because of bolt positions
Posted : 20/12/2015 3:28 pm
Ideal. Thanks for the info. I hadn't considered the fact it would only fit one way- I'm new to DM. Always had 4 or 5 arm cranks!
Posted : 20/12/2015 4:14 pm
Thanks for asking the same question I've been pondering since receiving my oval ring unexpectedly on Saturday, I thought they weren't due for shipping until early Jan!
Posted : 20/12/2015 6:55 pm
I fitted mine yesterday.. Was mentally tight and hard to get on... Had to persuade it with a rubber mallet in the end...
Posted : 20/12/2015 8:53 pm
I was told early Jan too. Then my pal above got his this morning (even though I ordered first!) then last night the postie bangs it in the door at 7pm.
Fitted earlier- only goes on one way. Looks cool!
Mine went on easy Carl!
Posted : 20/12/2015 11:49 pm
I'm toying with the idea of one. Any good? Is there a noticeable difference from a circular ring?
Posted : 21/12/2015 8:33 am
