PM to IS brake adap...
[Closed] PM to IS brake adaptor am I having a moment
[#6174323]
Ok building up a new frame with old brakes, so i need to mount a IS 160 rear brake (Hope mono) on a FF29 frame with a PM.
Does a suitable adaptor exist or i am having a failure to process mount?
Posted : 08/05/2014 9:28 am
there is one somewhere in the depths of the internet but PM to IS normally adds 20mm.
Posted : 08/05/2014 9:30 am
Giant used to do one and I think A2Z do too.
[edit]
wiggle list them but as discontinued;
[url= http://www.wiggle.co.uk/a2z-adapter-is-to-pm-to-keep-160mm/ ]http://www.wiggle.co.uk/a2z-adapter-is-to-pm-to-keep-160mm/[/url]
or is that the wrong way round. Some manufacturers put Calpier first, others frame.
Posted : 08/05/2014 9:31 am
I thought you had to add 20mm too - didn't think there was space for less
Posted : 08/05/2014 9:45 am
yes plus 20mm is the plan, halfords have the A2Z ones in stock so i'll try them.
now all i need is a 1.5 to 1.1/8 crown race reducer for a FSA internal headset.
cheers
paul
Posted : 08/05/2014 10:01 am
Hope Crown race thing should sort you - it goes on the fork, and your original crown race goes on over it.
Posted : 08/05/2014 10:05 am
KCNC used to do an adaptor which didn't require an increase in rotor size.
Posted : 08/05/2014 10:17 am
 bigG
Clee cycles sell the KCNC Post mount to IS brake adaptor that allows you to fit your 160mm brake without a need to increase rotor size. They also sell ones that allow you to go up by 20mm if that's what you want.
I fitted one to my PM forks to use my Hope 180mm front brake on a PM fork with no rotor size increase.
[url= http://clee-cycles.co.uk/esite/P1043/product ]buy it here[/url]
Posted : 08/05/2014 10:18 am
