I should be ok shouldn't i? I can't seem to find anywhere on the website that says that plus bikes won't fit on the trailers.
Wouldn't want to get there and find i have to ride up!
Please note any bike with a tyre wider then 2.75" will not fit onto our uplift trailers.
https://www.bikeparkwales.com/uplift
I went for the first time yesterday, its a hoot!
My rear 2.3" 650b Spesh Purg (i23) needed prising out from the trailer once the straps had been tightened.
I managed ok a couple of weeks ago with 3" Minions. You may just need to hang on for the first 2 slots in each trailer which are wider.
Most of the trailers have a couple of spaces at the front where the bars are spaced further apart to fit plus tyres in. You'll be fine.
Thanks all, don't know how i missed that on their website!
I've taken my Mojo3 a couple of times with 2.8 tyres on 42mm external rims. The first slot on both sides at the front of the trailer as extra wide, but I had no problem with any of the other spaces, other than the front sometimes needing a bit of a squeeze.
