Not the same bike, but I had a px kaffenback 2. I changed the OEM wheels (deore hubs and mach 820 rims) for a set of Hope/Archteypes. Everything else remained the same, tires, tubes etc.
The bike was transformed from something dead and wooden to something much more lively. Net cost to change was around £150 but worth every penny.
Oh, and been doing at least 100 miles a week every week since June 2013, split between Lapierre and a commuter/winter bike. Winter bike is on second set of pads but neither wheels (Ultegras on Lapierre, Aksiums on winter bike) show any measurable wear.
Not bad going I guess, how hilly are your rides though? Although I'd have thought commuting would wear out your rims quickly.
I usually do between 200 - 300 miles per week, although when I wore my rims out last time I was going up and down Wrynose pass quite alot I seem to remember, needs the brakes on the way down in the wet for sure, so thats what probably did them.
On every bike I've I've owned I've kept all the same decent kit and carried over onto a frame/fork. Upgrade the wheels/tyres is an investment as it'll be carried over too I guess.
Question (newbie)- can you use std road tyres with tubeless clincher rims?
No. For road wheels you need tubeless tyres to run tubeless as the bead needs to be stronger.
MrBlobby - But I think can use normal tyres with tubes on tubeless rims though?
yes, I have Ultegra 6700 wheels which are tubeless compatible (they come with the valves so all I'd need to buy would be tubeless-specific tyres and sealant) but use normal GP4000s with tubes.
my rides are rolling (oxfordshire) and most of the descents on my hill loops dont require much braking (either long flat run-outs or carry momentum into the next climb). Long and wet braking-heavy descents will definitely do rims quickly though!
I did that with the Ultegra wheels - bought them for the Ally Orbea, when I bought the Lapierre I swapped wheels and kept the Ultegras on the Lapierre. I noticed the difference between wheels, but I reckon the difference between crap OE and decent aftermarket, high-TPI, nice compound tyres had a bigger effect (for less expense).
Andyhilton- just remembered riding your ribble sportive with 400 £ carbon wheels. I didnt want to comeback. What wheels were those??
Good going! Wish I could say the same.
Hijack/since everyone is talking about nice road wheels, I have a set of [url= http://www.ribblecycles.co.uk/sp/road-track-bike/Zonda-Black-Clincher-Wheels-Pair/CAMPWHFR505?utm_campaign=Googlebase&utm_medium=organic&utm_source=Googlebase&gclid=CMTd7IPU_MECFY_ItAod2wMA3w ]Campagnolo Zondas[/url] I'm about to put up for sale. I bought them new in June or July, but I'm switching to discs on all my bikes. And don't worry, these haven't got knackered rims 😀 . After £170/hijack.
An old set of rs80s I think. Got some RS81s, Zipp 30s, Zipp 60s and Kysrium Elites knocking about too. Think I may have too many wheels!
Hundred !
(just to show I'm not just a wunundred-bagger, have a look at light-bicycle; they'll build you a set of wheels on disc hubs for about 400 quid)
(You need to make sure you get them laced appropriately for discs, though when I bought mine, their builder was obviously on the case already)
Ok Im on tomhowards lpaned wheels/GP4000's (maybe a placebo) but they seem comfier (softer compound?) And carry momentum better. A fair assumption/observation?
Yes, being light weight supple "race" tyres, that is what they are meant to do. It's more to do with the softer carcass.
Btw, what tubes was he using and what pressures did you run them at?
Yup, I'd say so..
Can you borrow a set of 60mm carbon jobbies too, for testing? Be a completely different feel again.
Bog standard Specialized ones, 90ish PSI when I left them.
What Mrblobby said, much higher TPI carcass is more supple, cheap OE tyres are often 60TPI, aren't GP4000S something bonkers like 320TPI? The casing is 'softer' not the actual compound.
AndyH- sell me one of your old un's!
Every days a school day. I wrongly assumed tpi was something to do with puncture protection.
Tpi:
Ultrasport- 85
GT - 185
4000s- 330
Bing!
Update- On I've ordered:
Conti's 25mm Conti GP4000s
Ultegra 6800 wheelset
Thanks Tomhoward for the loan- boy I didn't want to hand them back! Will drop off on Sat as promised. The tyres on yours were the final 'straw' to swaying me.
Cheers guys 🙂
Dibs if for re-sale
If you're getting GP4000 then do it properly and latex tubes too, well worth it.
PITA to get tyres on and off those Ultegra 6800's. Not impossible, just way harder/more fiddly than you'd like if it's cold and wet and need to stick a new tube in to get home.
I've bought the kit to go tubeless, but haven't got around to it yet. Sort of feels like I've thrown good money after bad as the 6800's weren't massively better than the OEM rims on my Giant TCR.
Look like a good set of wheels for the money... but then 250 quid is not a lot of money when it comes to nice wheels. You can spend that much on a decent rear hub.
Bear in mind some manufacturers are economical with the truth. Conti's 330 casing will be similar to a 110 casing, as they almost always have 3 plies of material under the tread,a s the threads are at an angle you get crossed plies, hence cross ply tyres (appart form the silly money maxxis radial tyres). Best to judge it relative to the rest of the range i.e. 330 is better than 185, better than 85, but not better than Schwalble 120tpi, and Schwalble 27tpi is probably equivelent to conti 85tpi.
and latex tubes
Which ones? Might as well whilst I'm building the lot.
Hora, I got the Michelin Air Comp ones. They say 23c but I run them with 25c tyres and haven't died yet. Been running them for about 6 months now and yet to puncture one. They can be quite easy to pinch a hole in when fitting the tyre though.
TINAS, how do you even know this stuff?! 🙂
Can't be any harder than with Conti/FSA Team 30's. I went and bought metal tyre levers after snapping 4 plastic ones.
I also have the powerful paws of a bear- powerful mitts attached to my wrists. After the fun and games with the tyre/rim it felt like my fingers had been peeled back/hands stretched for days.
Latex loses enough pressure overnight (or even over a very long ride) to require topping up, punctures easily, and can't be patched.
Just get lightweight butyl ones, they're as light as latex, feel like latex, but without some of the downsides. Conti supersonic weigh the same as latex tubes at 50-55g, michelin ultralight are about 80g and a bit more reliable, the valves on the contis fall off the tube if you look at them funny with a hand pump as the tubes so thin.
I have a huge capacity for really use[s]full[/s][i]less[/i] information.
That particular nugget I think comes from the Schwalble site.
I found lightweight butyl (mostly conti supersonic) to be much more puncture prone than latex. I'd just about given up on lightweight tubes before I tried latex. Much prefer latex. Feels nicer too IMO.
They do require topping up each ride but then I'm a bit fussy about pressures and checked and pumped before each ride anyway.
Maybe I was just unlucky, I just found them an allround PITA, hard to install, and punctured both withing 200miles. Settled on the michelin tubes, they seemed to be the best ballance of reliability/lightweight/feel, the lighter butyl tubes all split at the valve eventualy.
Shimano specifically state to avoid using levers of any description. I assume it's to avoid damaging the rim and preventing sealing with a tubeless setup.
I'll give you hard to install. I've lost one when fitting a tyre (bit of a bugger at 7 quid a pop!)
I used light weight butyl ones for a couple of years (mostly the Conti ones) and found them to be pretty fragile. I've yet to puncture a latex one on GP4000 running at 75/85psi. Reckon being more supple they are more likely to deform over stuff that would puncture light butyl.
Hadn't really considered latex till it was mentioned on here. Tried some back in the day on the MTB and they were rubbish!
I have a 5 year old SL pro which came with the stock wheels. For some reason they seem to be greatly affected by crosswinds, moreso than my cosmiques. Go figure!.
I have swapped them for Zondas and the difference was notable. The front end feels less "squirmy" and planted and the cornering gives much better feedback.
I don't feel the frame to be flexy as others say (I'm more Stannard than Quintana) and compared to my old school Ali Pinarello frame (which is stiffer than a teenager's bedsheets) it feels fine.
It did come with a fair stack height and shortish stem so maybe noodle around with reach and height first.
Nevis- what stock wheels were they? FSA?
Not really, they lose about 8-10 PSI/night, which means I pump up to about 110 PSI and commute for three days on 25c. Latex tubes are the easiest to patch, just use proper Rema TipTop patches and vulcanising glue and hey presto, the patches will stick like nothing else.
Where they suffer is in installation. They are so flexible that if the tyre bead does not seat perfectly, the tube will squeeze underneath and go bang once ridden - and the ensuing 10 cm slash means another £8 wasted! (well £16 in my case as I've done it twice). In fact I once had a screw hole in a brand new Schwalbe One and the replacement latex tube squeezed through the hole and exploded (how I learned to patch them!).
So if you don't mind pumping them up every three days, are careful with installation, and don't mind the extra rolling noise, they are light and have a sublime tubular-like ride.
I buy Michelin air comp from Decathlon.
?? 😐the extra rolling noise
Quick question (I've got anotherday before the tyres turn up)- The Ultegra 6800. Is there anything better out there for circa £225 thats also 1600gms?)
are you going to service the cup/cones yourself ? 😯
I can build a mountain bike from scratch. Apparentky its tooless?
**** it. What wheels upto £400??
RS80/81 or other??
Superstar Pave 28 are on my shopping list. New school wide road rims and decent weight.
Not sure that's true though I've read it before here. The warning stickers on my 6700 wheels (basically same wheel but 10spd hub) said not to hook levers around spokes, not that they can't be used on the rims.
Stans, a23, archetypes (all about 400g) etc on novatec hubs (mr ride, sokin etc on ebay, about 280g a pair!) all come in well under budget and start arround 1250g depending on spokes. You do have to build them, or pay someone who knows what they're doing with light road wheel builds, i did my own but its not as easy as MTB wheelbuilding.
or just go tubeless!So if you don't mind pumping them up every three days, are careful with installation, and don't mind the extra rolling noise, they are light and have a sublime tubular-like ride.
If I wanted light wheels to race on I'd probably get some of the Farsports wheels. The wider carbon one like [url= http://www.farsports.com/product/detail.php/id-199.html ]these[/url].
If it was for training and putting in the miles I'd get something like Archetype on whatever Shimano hub in budget. I've got one of the rims to build up at the moment with some DT Swiss Competition spokes. Bit heavier than the ones you were looking at but they'll make a good set of wheels. [url= http://www.wiggle.co.uk/h-plus-son-archetypeultegra-6800-road-wheelset/ ]Prebuilt here[/url]. For the price though the pre-built shimano ones do look pretty darn good.
I'm going for a set of Ksyrium Elite's which can be had for not much over £300 from [url= http://www.4thebike.de/laufraeder/rennrad/aluminium/8756/mavic-ksyrium-elite-s-wts ]here[/url], there getting more stock in a week or so apparently.
