I took the pads out of my Magura Louise brakes to replace them. Why they were out I cleverly stood on the brake lever causing one of the pistons in the caliper to pop out (and all the oil!!!). I cleaned the piston and slid it back in. Will I have caused any damage or anything or will my brakes be just fine once oil topped back up and bled?
Andy
Posted : 27/08/2009 10:28 pm
they should be fine once they are topped up and bleed.
just be careful when pushing them back in you dont damage the surface with a sharp tool. i always use a tyre lever.
Posted : 27/08/2009 11:08 pm
Should be Ok - if you are unlucky it can cause seal failure but 90% of the time you will be fine.
Posted : 27/08/2009 11:10 pm
