I found a tear in my bag's rain cover the other day. After looking on the web for a suitable patch to fix it and seeing some quite absurd prices with even more absurd postage costs, I thought I'd try a Park Patch as I've got a load sitting about.
It's gone on beautifully to be fair! A few days in it's still holding a perfect seal too. Will see how long it lasts and keep an eye on it, but so far it looks like a neat and cheap solution to a small tear in waterproof fabric ๐
Repaired a split in my camelback about 5 years ago, still going strong.
Same here!
+3 for the camelbak fix!
I've used them to prevent cable rubbing on the paint.
don't the badder fix with one also used one as a plaster.
worked well.
8 year old bladder still going strong.
This works but they go yellow eventually and are a pig to get off
+1 for using them to protect the frame against cable rub
(EDIT) - double post....oops!!
Never really been a fan of them as patches tbh but they're ace at other stuff
Yes a +1 for frame protection against frame rub.
Also use on hoses to stop them rubbing and have repaired waterproof jackets as well ๐
Tried once to repair a puncture - useless.
I used them as frame protection but they wore through to the sticky stuff. Made a right mess that was, as Beaker states, a right pain to remove.
I prefer the Topeak flypaper as they seem to be more flexible and hold better (on tubes anyway). I have yet to use on the Camelback, but small tears in a coat will be fine.
Used them to cover the holes when I removed my shifter windows, still going strong 5 years on.
Fixed a split in my welly with one. Holding out ok ATM...
Park Patches - Useless for punctures, great for everything else!
Worked a treat on my Thermarest Neoair.
I reckon a couple of patches could stop diarrhoea.
never had any problems with using them for repairing punctures...always work for me.
as for removing them off the frame...GT-85 seems to do the trick
I've used them on the groundsheet of a tent with no issues.
I also use the Lezyne ones for cable rub points on the bike frame.
Stick one over the Japs eye as a cheap form of contraception.
Your Mrs wont get preggers but you'll end up with a set of nuts the size of Water Melons.
glad its not just me. Their glue doesnt like high temperatures, we had a few punctures on exotic riding holidays which were Park self -adhesives peeling off with the glue essentially melting. Will bear in mind for the bladder trick though!
Got a row of 4 holding my snow board trousers together. Like the anti rub frame patch idea aswell.
