On One 456 Carbon o...
[Closed] On One 456 Carbon owners....
Thinkin' about getting this frame and wondered if there is an adapter out there that enables running a brake disc so it mounts on the outside of the seatstay instead of inside the rear triangle...and are there any limitations regarding rotor size etc....?
Posted : 26/03/2013 7:29 pm
Yes there is, running 203mm on mine...
Posted : 26/03/2013 7:36 pm
 nuke
Mine came with adapter to run on the outside of the seatstay as standard. My Scandal 29er V2 didn't
Posted : 26/03/2013 7:37 pm
Cheers...i have a 185mm disc and an Avid BB7 cable caliper i would like to bolt in.
Posted : 26/03/2013 7:42 pm
There's more wrong with the design of those frames than worrying about the disc mounts. Ask On One how to remove the headset lower cup, should you ever need to, I don't think you'll like the answer.......
Posted : 26/03/2013 7:49 pm
http://www.on-one.co.uk/i/q/FSOOCNCSO/on_one_cnc_anodized_swap_out
Posted : 26/03/2013 7:52 pm
It's not *that* much of an issue PP, just as long as you remember that the headset cup will be staying with the bike or get destroyed removing it...
Posted : 26/03/2013 7:54 pm
I'm intrigued...
Posted : 26/03/2013 7:56 pm
BB cup in vice, twist frame to remove. (May destroy headset cup in process)
Posted : 26/03/2013 7:58 pm
Any recomendations on suitable tapered BB Sets....?
Posted : 26/03/2013 8:08 pm
http://singletrackworld.com/forum/topic/more-c456-qs-headsets
Or did you mean bottom brackets?
Posted : 26/03/2013 8:14 pm
Mines on the outside of the seat stay too I asked for this as I wasn't sure if my
Mono M4s would fit inside the triangle.
As for a headset I've gone for a hope mix and match headset. Hopefully not have to change it too often as I can just replace the bearings as and when they're ever needed.
Posted : 26/03/2013 8:19 pm
Exactly. Be cause of a poorly designed head tube insert.
Now, what about the head tube that's too short for the taper on some Rockshox forks.......?
Posted : 26/03/2013 8:28 pm
Rock shox?
Who uses them anyway?? 😉
Posted : 26/03/2013 8:31 pm
I tapped the headset out of mine no bother (a medium). So don't ask about that, ask about the finish that falls off as if it has leprosy, and the warranty that they won't honour.
Posted : 26/03/2013 8:33 pm
My c456 came with an "outtie" as std too 😉
Posted : 26/03/2013 8:38 pm
 P20
Mine inside the frame, looks nice and tidy. 180mm hope mono4 on an 18" frame no problem. It means the bleed valve is pointing in the wrong direction, so bleeding can be a pain.....
[url= http://farm9.staticflickr.com/8506/8592570687_1de4b2744b_b.jp g" target="_blank">http://farm9.staticflickr.com/8506/8592570687_1de4b2744b_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/66452821@N00/8592570687/ ]Untitled[/url] by [url= http://www.flickr.com/people/66452821@N00/ ]ritcheyp20[/url], on Flickr
Posted : 26/03/2013 9:49 pm
Headset cups should tap out like any normal one, can't see why not.
Paintwork does seem to chip off from what I hear. Mine is raw and I don't have that problem 😉
Got straight 1 1/8" Recons and Smoothie Mixer. Been working fine and smooth for more than a year now. Some seem to have problems but I don't know why 😕
The thing about the tube too short for some forks is made clear on their site and applies to the 16" frames only.
Brake is mounted inside on mine with no problems but then it's a 160mm X0 at the rear.
Posted : 27/03/2013 2:11 am
 hora
Northwind warranty? What happened?
Posted : 27/03/2013 7:56 am
I needed to get an outside mount for mine to fit Avid Elixir brakes. The finish is pretty poor but I knew that when I bought it and at £250 I wasn't too bothered.
Posted : 27/03/2013 8:03 am
Exactly - i paid £250 for a new undecalled frame last August and i've been really impressed
The paint hasn't come of as quick as i thought it would
It rides great, hasn't broken (which is good for me) and is very light & stiff for a 140mm HT
I run a Hope mix n match headset. Haven't needed to remove it yet - but it can't be that difficult if you have the right tools
The cable routing is a bit poor, but lets put it into context - its a carbon HT frmae which will take tapered forks, a dropper seatpost and can be converted into a SS for the winter
And it cost £250....
Bargain of the year - thanks On-One!
Posted : 27/03/2013 9:38 am
hora - Member
Long story short- big chunks of finish came off, I got 3 different justifications to reject the warranty, all of which were wrong, then they admitted the frame wasn't compatible with helicopter tape but said that I should have bought one that was advertised as being compatible! Lost the will to live a bit at that point. Meanwhile, I know at least one other person with the same fault got a replacement frame...
It was a good bike and I enjoyed it but it's put me right off.
Posted : 27/03/2013 11:41 am
 hora
Weird as I always found Brant ok to deal with on such things- could it have been whilst he was away working in the CRC warehouse drawing on the back of packing cases?
Posted : 27/03/2013 11:50 am
Think it was just as he was returning to the fold. But you're right, he got involved with my first Mmmbop's warranty and it was really helpful (TBH I think CRC would have sorted it anyway but with his input it was so fast and smooth)
Posted : 27/03/2013 12:08 pm
