octalink crank remo...
[Closed] octalink crank removal??? Any tips and tricks?
Got a set of octalink cranks on a bike that i want off, I want to use them on my bike ๐Ÿ™ i have got the drive side off using chainring leverage but i did have to soak the whole thing in wd-40 for a few days first.
I now have it soaking again but im wondering is there an easy way to take this off? i dont see how a crank pull would work either with the bb being hollow. So is it just down to letting it soak and leavering it off(also no real place to lever from on this side)
I cant ride the bike to loosen them either as i dont have enough parts for the build. I dont really want to whack it with a hammer as i want to use them.
How much would an lbs charge for me to make this their problem?
what tool is available for this?
Thanks
lots
Tony
Posted : 10/04/2013 6:08 pm
Have you stripped the threads that the crank extractor screws into ?
If you have use an auto motive puller or ball joint spliter
Posted : 10/04/2013 6:18 pm
A crank puller with [u]two[/u] coins on the end to stop it going inside the axle..
It's been that long since I did one I can't remember if its 1p or 5p coins, but whichever it is use two, if you use one it gets mangled up..
Posted : 10/04/2013 6:19 pm
It's like google doesn't exist
[url= http://www.parker-international.co.uk/16865/Pro-Crank-Removal-Tool---For-Square---Octalink-.html ]http://www.parker-international.co.uk/16865/Pro-Crank-Removal-Tool---For-Square---Octalink-.html[/url]
There is a crank pulling tool with a larger 'plug' in the middle that doesn't get pushed down the hole in the middle. [url= http://superstar.tibolts.co.uk/product_info.php?cPath=36&products_id=384&osCsid=84c27c348ad61204ae5972e40786654e ]like this one.[/url] Years ago I got one from halfords which had a cap that comes on and off so you can do both square taper and isis/octalink/howitzer with the same tool but its not as nice or expensive as the park tools one.
If you have a crank puller for square taper only, I have heard of it being done using a 5p piece to go over the hole in the spindle before you insert the tool. You will knacker the 5p though!
Posted : 10/04/2013 6:20 pm
It's not like it's the latest top-of-the-range Campag BB...
http://velonews.competitor.com/2013/04/bikes-and-tech/how-to-remove-campagnolo-power-torque-cranks_280400 ๐Ÿ˜†
Posted : 10/04/2013 6:21 pm
Incidentally, I have a domed head coach bolt that I stick in mine as I only happen to have a sq taper crank puller.
Posted : 10/04/2013 6:22 pm
Power torque " top of the range" ultra torque maybe
Posted : 10/04/2013 6:23 pm
 Keef
1p.
5p too small......... 8)
Posted : 10/04/2013 6:28 pm
That's only cuz you don't want to wreck a 5p ๐Ÿ˜†
Posted : 10/04/2013 6:35 pm
You are remembering to undo the hollow 10mm bolt that's in there? Then like the others say, a 1p used as a plug should do the job!
Posted : 10/04/2013 6:36 pm
My local lbs gave me a metal stud that you put in front the crank puller instead of the 1ps.He had a box of them and said that they used to come free with Octalink chainsets.
Posted : 10/04/2013 6:48 pm
mine all came with self-extracting bolts, are you sure yours don't ?
look a bit like this
Posted : 10/04/2013 7:20 pm
For postage and a bottle of beer you can borrow my octalink crank puller...
[url] http://www.merlincycles.com/bike-shop/workshop-tools/tools/tools-workshop/park-ccp-4-pipe-billet-crank-puller-octalink-isis.html [/url]
But it's prob cheaper to buy one, or if you support your LBS they will prob do it for very little indeed...
Posted : 10/04/2013 7:34 pm
Think mine was a fiver of ebay
Posted : 10/04/2013 7:42 pm
