novice wheel build ...
[Closed] novice wheel build question
4 Users
Hi gang.i want to change my rims from syncros dp25 on pro2
to stans flow rims.
my question is is it just a strait swap or am i missing something like spoke length or anything else.
cheers guys.
Posted : 25/10/2010 9:37 pm
Probably best to use new spokes, and they'll probably be a different length too
Posted : 25/10/2010 9:39 pm
ok dave but what size spokes(novice) 😕
Posted : 25/10/2010 9:42 pm
wheelpro have a spoke length calculator. Roger is also selling a set of handbuilt dt wheels if anyone's interested.
Posted : 25/10/2010 9:52 pm
Not a clue, put your info into these and see what you get:
http://www.dtswiss.com/SpokesCalc/Calculator.aspx
http://www.wheelpro.co.uk/spokecalc/
Or you could email hope and see what they use on the "hope hoops" wheels
Just compare the effective rim diameter of the two rims. Anything up to a couple of mm might be worth a try with the existing spokes
Posted : 25/10/2010 10:18 pm
cheers onza.just needed the (couple of mm)verifying.
Ta bud...
Posted : 25/10/2010 10:41 pm
