Nice road frame wit...
[Closed] Nice road frame with a BSA threaded BB
11 Users
Right then, I'm fed up of my frame with a press fit BB, neither me or my LBS can get the bugger to stop creaking so I'm heavily debating just buying a new frame.
I'd like a good, racey frame and fork package with threaded BB and ideally with a neat way of routing Di2. Steel seems like a nice option, either from Condor or Richie but in honesty, I think carbon is a more sensible option.
Cost is not too much of an issues, £1k is fine, £1.5k maybe as a top line.
Any thoughts?
Posted : 14/07/2015 9:56 am
If you want to go disc, how about Mason? Internal cables, Di2 compatible and threaded BB. I've just bought a Definition and it's lovely.
Posted : 14/07/2015 10:06 am
Mason Cycles. Either his alu Definition or the steel Resolution. Both get cracking write ups on road.cc with the tester buying a Definition frame for himself. Just ordered a Definition for myself in fact.
Bah, got distracted mid post and beaten to it!
Posted : 14/07/2015 10:11 am
Praxis BB for your current frame?
Posted : 14/07/2015 10:15 am
 moff
How about this https://masoncycles.cc/products/resolution-frameset
Posted : 14/07/2015 10:16 am
Upgraded BB, Hope in this case is already in place, it's made little or no difference.
Don't want disks at the moment as I want to move my existing wheels and build onto a new frame.
Those Mason frames, nice though they are, aren't quite what I'm looking for.
Posted : 14/07/2015 10:31 am
chose the frame you want and worry about the BB later.
a praxis or wheels MFG bb. not a BB-30 adapter but a BB that will always have parallel bearings and is 2 halves screwed together as one unit.
Due to not wanting to deal with BB30 i asked for a BSA bb on my last custom frame but those Italians like to do their own thing so it turned up with a BB-30. currently using a wheelsMFG bb with no creaks and have a praxis one spare ready to use if/when the bearings eventually go in the WMFG one (i’ll get them pressed out and replaced)
Posted : 14/07/2015 10:43 am
I did that and ended up for a creaky pressfit BB. Logical or not, I now want a frame with a threaded BB.
Posted : 14/07/2015 10:48 am
I can't think of any modern carbon frame that has a threaded BB at the price range your talking about (which clearly limits your choices).
The Colnago C60 uses a hybrid BB, with proprietary threaded cups that then accept press fit cartridge bearings, but that's about three times your budget.
My Condor (Leggero) has a press fit BB30 and it's been fine; no creaks no issues. I think that merely suggests that the creaking issue is more about the frame than the BB specification.
I'd never suggset you don't buy a new frame because what's not to like about buying a new frame, but I would suggest that you make your spec list 'I want something that doesn't creak' rather than 'I want something with a threaded BB'.
That said a Genesis Volare 853 would do the job as would a Condor Acciaio (the Super Acciaio should also be considered as a good example of my point above. It's BB30, so press fit, but it's in a steel housing so the tolerances are likely to be better and less likely to creak).
Posted : 14/07/2015 11:29 am
Praxis option FTW IMO
Thinking about it some more, £1.5k would buy you a very nice steel custom frame from Rourke.
Posted : 14/07/2015 11:31 am
Yeah dont worry about BB option, Ive got a stumpy carbon with PF30 BB and a CAAD10 with BB30, both running praxis works adapters to use shimano 24mm, both silent and rock solid many miles in.
Posted : 14/07/2015 11:32 am
So, this Praxis option, anyone got a link for the PF86 version? I can find a BB30 one but not this size.
Posted : 14/07/2015 11:33 am
Aren't all the Pinarello's still using threaded BB's
Italian of course, but threaded.
Posted : 14/07/2015 11:35 am
Steel, carbon and alloy frames here: http://www.chickencycles.co.uk/index.php?cat=54&sub=129&ord=2
The steel one looks good!
Some more here: http://www.chickencycles.co.uk/index.php?cat=54&sub=125&ord=2
Posted : 14/07/2015 11:47 am
What about a Planet X?
Posted : 14/07/2015 11:58 am
Or, keep your eye out for old Cannondales/Giants on ebay; great frames with threaded BBs
Posted : 14/07/2015 11:59 am
