New cassette
[Closed] New cassette
6 Users
replacing the cassette on an Orange crush 2010
Sram PG 950
but is it 11-32 or 11-34
many thanks
egn
Posted : 25/10/2010 9:35 pm
whatever you want (esp if you're replacing chain as well - can make it the right length)
Posted : 25/10/2010 9:39 pm
Depends what chainrings you are running: I run a 11-34 because I run 26/34 chainrings, although I would like to swap to a 11-36 and get rid of the 26 if at all possible.
Posted : 25/10/2010 9:49 pm
I'd always get 11-34 myself, slightly wider range and not an appreciable difference in gaps.
Posted : 26/10/2010 7:21 am
You can count the number of teeth on the biggest cog and find out for yourself if you want. If you have a triple I would get 11-32, if you have a double or single ring I would go for 11-34.
Depending on model 11-32 can be about ~50g lighter if you worry about that sort of thing.
Posted : 26/10/2010 8:17 am
Its usually written on the sprockets IIRC 🙂
Posted : 26/10/2010 8:34 am
