Need some help with...
[Closed] Need some help with a bearing size
Hi
Have a small kids bike donated to me from a friend, on the service i was giving it before my niece gets it as a pressie i opened up the Bottom bracket area to re-grease the bearings, that was my first mistake.
The caged bearing race collapsed and guessing they'd be easy parts to replace i ditched the pair of them.
Now the problem, i cant find replacements, in the several LBs i've been in or online.
I can confirm that they're not BMX size cups but slightly smaller, crankset is a one piece with chainring attached.
Latest bearings i've tried are 1/4" caged races, these are too small. However the Bmx race's offered by the shops are too big to fit into the BB shell.
I need help, i need an online supplier of the bearing please or else i'll have one very upset Niece.
Can answer any questions in the pursuit of tracking the bearings down.
Posted : 03/03/2011 3:15 pm
can you pack them with some free bearings and put enough in of a reasonable size to sort it?
Posted : 03/03/2011 3:17 pm
tried that but the act of threading the one piece crank in, plus the difference in the cup and cone has made it a near impossible task. Although that is the last chance plan.
Posted : 03/03/2011 3:19 pm
Enough grease in teh cup should hold them in, tricky to help remotely on this.
Posted : 03/03/2011 3:23 pm
absolutely agree, exhausted the options locally so trying the hive mind.
Posted : 03/03/2011 3:34 pm
for an ordinary bearing you need inner/outter dimension and width as three figues to search online for a replacement.
if you measure the outer dimension and work out the inner one by measuring the crank you maybe able to source a suitalbe replacement using the WWW. I find most of my bearing on E-Bay.
Good luck
Posted : 03/03/2011 3:54 pm
I wonder if good ol' Sheldon can shed some light on this;
http://www.sheldonbrown.com/gloss_bo-z.html#bottom
http://www.sheldonbrown.com/opc.html
Might be worth a read as there are slightly different size systems used.
Totally agree it's virtually impossible to use loose bearings in a one piece crank - if ever there was a need for cages it's here.
Posted : 03/03/2011 4:18 pm
coleman the first link shows the style of the bottom bracket it's a 'ashtabula' style, though i'm not sure if it's a standard size for kids bikes as well as adults.
The crazy thing is i believe that pretty much any kids bike that uses the one piece crank is the same as this bike, i just cant find the bearings.
grrrrrr
edit ... just looked at the second link and it could be a 5/16th bearing but the number of bearings within the cage are the important bit. Need to look through what i've already tried
Posted : 03/03/2011 4:28 pm
Sorry can't offer any useful advice.
I've only come across different 24 & 28 tpi threads, both take 5/16 bearings, and as you correctly say the number of bearings, but the cages are diff. size and not interchangable. Have found these on a mixture of kids, bmx and cruisers.
Hope you get it sorted.
Posted : 03/03/2011 4:37 pm
