need help with luft...
[Closed] need help with luftkappe in 36 rc2
hi all i fitted a luftkappe to my 2017 36 rc2 forks and they are not an improvement the forks can have the travel adjusted i think the previous owner changed the travel but how would i check ? the travel measures 180mm the forks originally were 170mm
can anyone point me in the direction of what to look at/check cheers
Posted : 13/05/2020 9:49 pm
 isoo
You should have a sticker behind one of the fork legs just below the dust seals with four letters/numbers in it. Input those here , where it says 4 digit code to find out the original specs of your fork.
I think I remember reading that the Luftkappe might not play nice with really long travel forks, but no personal experience.
Posted : 14/05/2020 7:39 pm
cheers found out it was lengthened to 180mm but they didn't move the transfer needle to the correct position
Posted : 17/05/2020 5:36 pm
