My Tracks GPX probl...
[Closed] My Tracks GPX problems importing into Memory Map.
4 Users
Running My Tacks on my phone at the moment and its all dandy. However, when I try to import the GPX into Memory Map, it wont do it. Memory map lists the track in the tracks section, but there is no detail contained within its properties and it wont show on the map.
Any ideas ?
Cheers all.
Posted : 24/02/2010 7:41 pm
no ideas?
Posted : 25/02/2010 7:34 pm
Dave, for a start you might try opening the .gpx file in a text editor to check there are valid trackpoints in it - it's XML which is plain ASCII
Or send it to me and I'll have a look-see 🙂
Posted : 25/02/2010 7:42 pm
Are you using the current version of MM? (5.4.2)
It may be worth asking your question here too:-
[url= http://www.memory-map.co.uk/supportforum/viewforum.php?f=23&sid=0b5b1dbe354c34f5dcac834080e77565 ]MM forum[/url]
Posted : 25/02/2010 8:20 pm
Cheers simon, I'll mail it to you tonight.
Posted : 26/02/2010 2:56 pm
My Tracks will record your route as a 'track'. If you want to use it any kind of GPS device (or I suspect mapping software) you will need to convert it to a 'route' or other useable file format
See [url= http://www.gpsies.com/convert.do ]GPSies.com[/url]
Posted : 26/02/2010 3:00 pm
Cheers bonesetter... that looks interesting. I'll give it a try.
Posted : 26/02/2010 3:21 pm
