Mudguards for Charg...
[Closed] Mudguards for Charge Plug
What are you using? Mine is the Plug 3 and came with 40mm tyes.
Posted : 07/01/2018 2:30 pm
Drilled, cut and bodged? 😯
Posted : 07/01/2018 5:09 pm
Oh yeah, first time fitment of proper mudguards is a royal PITA. Worth the effort, (or possibly cost of getting the LBS to do it) for the benefit though. Subsequent removal and refitment is a much easier prospect. I've found Zefal ones to be as good as SKS in the past, just depends what you can get for a reasonable price.
Posted : 07/01/2018 5:49 pm
My sks ones fit fine over 37mm vittoria voyager.
It’s a 40mm one.
No bodging necessary.
Got from Decathlon for £12 in a sale ages ago.
Posted : 07/01/2018 6:03 pm
Yes, needed to drill new holes in guard to reposition the main top of fork and BB mount positions.
Trimming stay legth was a bit of a faff, used a cutting disc in a grinder for that once I had set them at the right length.
Bodge needed to keep the front left stay clear of the cable pull on the brake. Also needed to bodge a longer threaded bar through the top of the fork as the supplied bolt wasn't quite long enough.
All in all a bit of a faff, but once set up they are great.
£23 from CRC+a couple of hours of fiddling Vs RRP and a bit of workshop time at LBS.
Can send photos if you want.
Posted : 07/01/2018 6:05 pm
