has anyone got any idea where I can get some spares for the mobi washer? I need the little o ring's that fit on to the adapter for the hose, that stop water spraying everywhere
sadly ive lost it so I cant even get the measurement....there is a spares kit on CRC for this but everysingle review says they do not fit so pointless buying them
any ideas appreciated
If you Google it you can find a parts schematic for the Sealy PW1712 which is the same thing. Once you've found your prt number just Google that and you'll find parts easily enough.
I think I used CPC Farnell for parts for mine.
cheers for that - typically its got everything on that diagram bar the bloody one area I need the or ring for
do you know if the o ring on the base connector is the same as the o ring on the trigger connector?
as that does have a code and is 7x2mm
appreciated
Is the o-ring not shown on here?
