Just back from MM and have reserved an acre of real estate with electric fencing 8)
Using the map from this thread: http://www.singletrackworld.com/forum/topic/mountain-mayhem-course-map Marshall Point 6 is in the middle of the field, not in the south as positioned on the map.
All camping has been reserved on the four corners where the track crosses via a bridge on the out bound route and under the bridge on your return.
From M6 in the centre of the field take the short track up to the main track which is used by riders to get to the transition area. Where these two tracks meet and down to the arena, this road will be CLOSED from 8am on Saturday to ALL TRAFFIC. So if you are camping south of this junction you need to be there early!!
From the other direction, all camping is taken up on the first available spot on the right hand side unless you wish to camp on a slope. The small field on the right hand side is closed off and inaccessible. All camping is taken on the first field on the left hand side. Solo's are camped at the south end of the whole area and accessed by turning left as soon as you turn off the main road.
There's one big hike to the transition area too.
