HELP: Marzocchi 66 ...
[Closed] HELP: Marzocchi 66 RCV 2011 setup
[#2858294]
Please help as the Marzocchi manual is a little confusing.
I believe that in order to setup my forks I need to start by setting the preload / sag and then having a play with the Rebound and Compression (starting with it at it's lowest and increasing as it bottoms out / feels unresponsive) [is this right?!].
My (main) issue is that the manual gives recommended air pressures for selling the air preload, but doesn't say what to do with the mechanical adjuster for coil preload -Please help.
Thanks, James.
[edit] Also, how much sag do I need?
Posted : 16/06/2011 2:53 pm
 LoCo
http://locotuning.co.uk/tech-info.html
have a look at my setup guide for sag, rebound and compression setup, try them with no air pressure first and then increase in v.small psi increments
Posted : 16/06/2011 2:59 pm
If you email the technical contact at Windwave and tell him your weight and riding style he'll make soime recommendations for you.
Posted : 16/06/2011 3:01 pm
Thanks guys, the website looks really useful and I'll call Windwave tomorrow.
Posted : 16/06/2011 7:03 pm
