Does such a map exist?
I have OS Maps access but it can be very difficult in the area where I live to pick out a routes.
I want to try and create routes for my road bike that include all of the above. Does a map exist that allows you to show just those options?
Strava is no good as it will include all cycling, which could obviously include steep MTB trails.
THanks
I have OS 1:25,000 on my phone and GPS - easy to see the different track designations.
I'll be honest, I don't get why an OS map isn't perfect for that.
Roads - obvious
BW - long green dashes
Green lanes/cycle paths/other bikeable RoW - green dots
What else do you need?
1:50k is sometime easier than 1:25k as it removes some of the 'distracting' detail.
Try rowmaps.com.
Puts an overlay on various different maps (OS< bing, openstreetmap etc.)
You can filter the footpaths out by the way.
Thanks Benjim thats what I was after, although even that isnt comprehensive, stuff that I know is a green lane isnt marked.
At least I can use that as a guide and plot with Viewranger.
Bikehike has OS map view too.
Just use Komoot it’s the best route planner as you can tell it what sort of bike you are riding and it plans routes accordingly.
Obviously it’s not 100% but it’s a great start and you soon realise which bits to reroute once you have actually risen them.
It also classes roads as highways, B roads and county lanes and you can highlight each category and reroute to avoid busy roads.
It also classes off-road sections into single track, fire roads, bridle ways and footpaths etc and you can highlight each category and reroute those.
It also has suggestions from other riders that you can incorporate into your route where they leave descriptions and pictures.
Some people don’t like it but I can’t see any downsides with it.
Any app that shows OpenCycleMap data? I use ViewRanger.
I was trying to do this last night using Ride With GPS. I was highlighting all the sections I know that are good for gravel bikes to try and create a 'fast' traffic free route with minimal slogging through fields using the 'Add' function, but it would only let me select and save individual segments.
Is there a route planner that will let me highlight sections of preferred trails and save them in one map so I can link them into larger loops as and when?
The easy option would be a good old paper map and a highlighter but I'd like to be able to keep changing it!
Green lane is not a legal definition, but a descriptive one. As such green lanes are any lane with a grass or mud surface. If they are not marked as PROW or ORPA on OS mapping 99% with be illegal to use.
Have you tried looking at your local council definitive maps?
Slowoldman +1
I believe higher rights exist on this route and will continue to exercise them until settled by public inquiry
Unless you are on a MX or 4x4 and then you should have it confiscated
The TRF used to have an online map that showed 'green lanes' and their status, pretty sure it'll still be there
+1 www.bikehike.co.uk
And if you know any that aren't on it, go to OSM and add them.
Yes that idiot attitude that what I'm doing is alright but other user groups that I don't like shouldn't be allowed. By the same token a walker or horserider can use that self same argument against you.
What is indisputable is that higher rights that may exist will be down to vehicle usage in the past, not walkers, and since it is a lane probably not equestrian usage.
