M675 rings on M665 ...
[Closed] M675 rings on M665 cranks?
[#6947808]
As title- can anyone confirm if I can put 24/38 M675 2x10 (or M615 for that matter) rings on my M665 double and bash cranks in place of the 22/36 rings which are goosed. With or without the bash is fine.
I've found with moving to 10 speed out back the lowest gear (22x36) is too low to be useful so may as well put bigger rings on. Looking at photos the profile of the outer ring looks a bit different around the tabs. Will they go on on the "middle" position of the older cranks?
Posted : 21/03/2015 8:10 pm
The ring offset in the 675 double is true 2x10. Depends where they put the packing really.
Even if they physically bolt up your shifting may be a little off.
Posted : 21/03/2015 9:15 pm
So is there a different gap between the rings on a dedicated 2x10 than granny and middle of a triple?
I thought it was just chainline ie both rings moved out by a small amount?
Posted : 21/03/2015 10:15 pm
Without taking cranks apart I'm not sure, but my impression was that while the rings themselves are placed further out, there's also a slightly greater distance between them.
Posted : 22/03/2015 1:49 am
I found an old thread that suggests there is no difference in the gap.
After all derrailleur throw is the same on all front derrailleurs.
Issue is just if there is any difference around the tabs that would mean 675 rings only fit 675 spiders. Only one way to find out I guess. Rings are quite cheap at merlincycles
Posted : 22/03/2015 10:03 am
