Low=stack headset.....
[Closed] Low=stack headset.. need more mm's
I want to see if i can reduce the overall stack height on my frame. I have a pair of forks that are just a bit short for the headtube, which i want to use on my frame.
I'm running a standard type headset (FSA pig i think) and wondered if there's anything which is super low-stack?
It's 1 1/8th size, and i need to lose about 8mm.
Posted : 31/08/2010 2:08 pm
 nuke
Crank Bros headset...21mm stack height
Some FSA stems...35mm stack height
What's your headtube length and what's your steerer length?
Posted : 31/08/2010 2:09 pm
Crank Bros do very low headset - 21mm IIRC - Cobalt directset - £60ish
http://www.wiggle.co.uk/p/cycle/7/Crank_Brothers_Iodine_C_Directset/5360036704/?referid=frogoog&source=googleps
Or a FSA Orbit XL2 is about 27.5mm and only £20
Truvativ XR stems are low stack and having a single bolt fitting are better suited if the steerer's a bit low in it.
Posted : 31/08/2010 2:12 pm
I've managed to shave nearly 10mm off the required steerer length by fitting an XR stem.
If i needed to lose any more i'd go for the FSA headset, rather than the CB headset as they seem to be pants (keep the receipt!)
Posted : 31/08/2010 2:23 pm
err... well i'm at the office so cant remember specific sizes.
Great tip about the Crank Bros 'tingy. I'll do some measuring later, and see what i need to lose.
I can lose some of the stem, as it's a Easton vice right now.
It's all going on my winter-hardtail-jumpy thrasher bike. SO, weak stem would not be a good move.
thanks all.
Posted : 31/08/2010 2:28 pm
 nuke
+ 1
...CB is the lowest but if you can get away with it FSA are cheaper and more reliable. I'm running a CB but have XLII on my other frames. XLII is £15 including P&P at On-One at the moment.
Posted : 31/08/2010 2:32 pm
