Leaking motion cont...
[Closed] Leaking motion control damper
My forks have biiig incontinence problems when they're turned upside down (+/- 2007 Boxxers) - all the oil wees out from around the motion control damper.
I think this *might* be secondary to be toying with the circlip on the floodgate whilst trying to take them apart. Assume I've disturbed a seal?
TFT don't sell new kits (not that I can find) but am happy to go searching for o-rings...if I knew what to search for. Any suggestions?
May be a similar problem as here?: http://www.singletrackworld.com/forum/topic/revelations-leeking-around-motion-control
Posted : 27/01/2011 11:04 pm
I may well have just found the answer to my question with this: http://www.singletrackworld.com/forum/topic/puffing-pikes
A very nice exploded diagram from someone - props!
Posted : 27/01/2011 11:40 pm
I had this problem a few times so took some pictures. Hope it helps you: [url= http://www.basquemtb.com/repair-leaking-pike-motion-control/ ]Fixing my leaking Pikes[/url]
Posted : 28/01/2011 8:51 am
Posted : 28/01/2011 8:56 am
Mine did the same and the fix was similar to doug_basqueMTB above. The umbrella seal should stop the oil getting to the top cap in the first place.
Posted : 28/01/2011 8:58 am
Cheers chaps, thanks for the tips. I'll give it a shot this weekend & get a seals kit if I need one... I presume TFT do them but I can find anything on their website....? Maybe a quick phone call.
Posted : 28/01/2011 9:24 am
I think that TFT do an improved seal kit. Worth speaking to them, they're very helful.
Posted : 28/01/2011 9:25 am
