layback setback sea...
[Closed] layback setback seatpost question
thinking of trying one but is there any cheap and cheerful ones i can try before spending on a decent one ? are they any good ? got a large frame but feel a bit over the bars at times......
Posted : 27/09/2013 10:21 pm
Be careful, i think you should only get a layback if its the last resort. knee position over the pedal is important. I had a layback saddle on one of my frames because the frame was on the small side, mine worked for me. Have you thought about extending the stem?
Posted : 27/09/2013 10:34 pm
highly recommend this
http://www.chainreactioncycles.com/truvativ-stylo-t40-seatpost-2012/rp-prod71779
bargain at £40, sorted my knee pain out a treat as gave me more space on current short top tubed Heckler.
[URL= http://i237.photobucket.com/albums/ff100/capoz77/20130919_184717_zps3a44a88d.jp g" target="_blank">http://i237.photobucket.com/albums/ff100/capoz77/20130919_184717_zps3a44a88d.jp g"/> [/IMG][/URL]
[URL= http://i237.photobucket.com/albums/ff100/capoz77/20130919_204416_zps678e2e49.jp g" target="_blank">http://i237.photobucket.com/albums/ff100/capoz77/20130919_204416_zps678e2e49.jp g"/> [/IMG][/URL]
Posted : 27/09/2013 10:59 pm
Alot of bikes an. Frames were necerdesigned to have an inline post anyway.
They dint need to be bent like thomsons but can look like post above !
Posted : 27/09/2013 11:14 pm
They're not good or bad, they're just different. Many frames are designed with a layback post in mind so those will be better for most with that rather than an inline one.
It's a bit like asking what size frame is fundamentally best.
Posted : 27/09/2013 11:18 pm
 nuke
FSA do some good layback posts at reasonable prices. Use layback posts on all my bikes...would rather use a layback seat post than mess with the handling for the downward bits on a ride by changing the stem length.
Posted : 27/09/2013 11:22 pm
thanks for advice guys , cheers
Posted : 28/09/2013 7:53 am
@banjax34 I liked the truvativ as it gave a full 25mm/1 inch of setback, I was tempted by the thomson but only 16mm, as were many others.
Posted : 28/09/2013 6:21 pm
