Is there a headset ...
[Closed] Is there a headset that allows for a 1 1/8 fork to fit on a cannondale?
[#3282349]
As the title really. Can anyone recommend one, or am I stuck with the one that my new bike will come with?
Posted : 26/10/2011 10:11 am
As far as I know, any 1.5 to 1 1/8 headset will do the job - I've got an FSA Orbit Z in my Rush and it works a treat.
Posted : 26/10/2011 10:15 am
BETD make specific reducer cups allowing a greater flexibility in choosing the headset:
[url= http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=169&Name=Headset+Reducers ]Clicky[/url]
Posted : 26/10/2011 10:18 am
There definitely are reducer headsets for 1.5" to fit 1"1/8 forks.
Need to check compatibility, as Hope do one, but say its not Cannondale compatible.
Here's an example - http://www.chainreactioncycles.com/Models.aspx?ModelID=38693
edit - ah, yes those reducer cups are what I had on my old 'Dale.
Posted : 26/10/2011 10:19 am
I thought Cannondale headsets were just 1.5 headsets so most 1.5 to 1 1/8 reducer headsets should work (this may not be correct but i'm about 80%).
BETD do reducer cups for cannondale bikes to allow you to fit standard headsets if they are of any intrest.
you could have a look on the Hope web site, they now do pick and mix headsets to allow you to buy the upper and lower cups of your choice, they do most of the common standards so may have what you need.
Posted : 26/10/2011 10:21 am
I've got hope reducer (stepdown) headsets in my 2 Dales
Posted : 26/10/2011 10:22 am
I'm using a Hope Stepdown on a Prophet with no problem, cups went in fine.
alloy cannondales are generally 49.6mm so standard 1.5, the carbon ones and some alloy stoff that came with headshox or lefty forks can be 50.6 so you have to buy a cannondale branded headset, a nightmare to find in the uk but the guys (and girl) at http://www.cannondale-parts.de are your friend as i fount when trying to fit a tapered fork to a carbon rush
Posted : 26/10/2011 10:27 am
[i]I'm using a Hope Stepdown on a Prophet with no problem, cups went in fine.[/i]
Cool, I was just going by the CRC description:
[i]Takes 1.5” headtube (only, not a Cannondale) down to use a 1 1/8” fork.[/i]
Posted : 26/10/2011 10:30 am
I use the hope one on my prophet, works fine but does raise the head by about 10-15mm (the original cannondale adaptors did too). I think this might be something to compensate for lefty's being a taller fork or summink.
Posted : 26/10/2011 10:34 am
Thanks all.
Posted : 26/10/2011 10:49 am
Hope do 2 stepdown headsets, a HS (high stack 10-15 mm) and a LS (low stack 3mm) just get the one that suits!
Posted : 26/10/2011 12:23 pm
[url= http://singletrackworld.com/forum/topic/anyone-running-a-cannondate-rz-with-1-18-forks ]Another thread on the subject[/url] and the Hope headset get a mention, along with a comment that it will fit.. maybe worth ringng Hope to confirm.
Posted : 26/10/2011 2:00 pm
I can also vouch for the Hope 1.5 step-down working on an aluminium Cannondale. Have one fitted to an old F2000 frame with an 1"1/8 fork on it.
There may be an issue with Cannondale fitment regarding the depth of the cups into the frame. A lot of 1.5" step-down headsets have cups that insert a long way, the Hope insert only by about 10mm and are fine.
No problems using it at all.
They won't fit a carbon frame though, different insertion for the cups.
Posted : 26/10/2011 5:27 pm
