Is the difference t...
[Closed] Is the difference twixt O/S bars and normal size noticeable and more betterer?
I think the human body is an incredibly sensitive instrument and can detect small changes in many inputs, all of which add up to a sense or feeling of how something is going.
TJ unfortunately cannot sense when he is wrong, despite all these inputs.
Posted : 14/09/2010 3:27 pm
we have nothing yet to establish if increased stiffness matters...
are you a virgin? Stiffness is vital. 8)
Posted : 14/09/2010 3:42 pm
think rather that we can easily imagine things that are not real 🙂
stiff as opposed to floppy perhaps, but I think most women would prefer a velvetty knob to a broom handle 🙂
Posted : 14/09/2010 3:49 pm
SFB appears to be advocating a new suspension system:
floppy handlebars...
Posted : 14/09/2010 3:50 pm
I think it was rather an appeal for appropriate metaphor
Posted : 14/09/2010 3:52 pm
ah , classic hinting at arcane knowledge only
revealed to the few ?
Not at all. Less flex in your front end helps you control the bike. To think its just about steering and torsional flex shows you just don't get what the basic issues are.
Posted : 14/09/2010 3:53 pm
A basic misunderstanding there mister SFB, mine is velvety on the outside and like a drive shaft in the middle. Superstar grips give that soft feel.
Posted : 14/09/2010 3:55 pm
Posted : 14/09/2010 3:56 pm
it's all very well to say that, but if it's only millimetres then it's probably negligible
if you imagine there is anything other than those 2 things you are delusional
uh bike twisting along longitudinal axis relative to bars? 🙄
Posted : 14/09/2010 4:15 pm
or flex up and down of bars on take off/landing/climbing/pedalling/braking?
Posted : 14/09/2010 4:18 pm
ie not part of the bars at all ? Or do you mean stiffer bars stiffen the frame too?
yes,
3) non torsional loading 🙂
Posted : 14/09/2010 4:29 pm
Maybe it's noticeable with rigid forks but with suspension there's really no difference that can be felt unless you're changing the material type.
Posted : 14/09/2010 4:31 pm
In truth whilst I think the bike industry is packed with marketing guff, I do not think this would have had industry and market wide acceptance without some justification of it benefit. I am 100% confident that OS bars are stiffer, I think I can notice it, and there are some really obvious reason why this is better.
I am sure that over the years bikes have got better at what they do, my 1992 rockhopper does not feel as awesome, over, rooty, jumpy, bermy, bumpy course as my 2009 Mountain cycle battery with totems and oversize everything. All these things are incremental and small things are additive.
Posted : 14/09/2010 4:33 pm
carbon bars as they " remove trail buzz" ie they flex
No, they probably do have a greater dampening effect on vibration though, so when they do flex they don't vibrate up and down afterwards.
Bigger clamp area helps as well, big area, lower stress, lower clampng force required.
Posted : 14/09/2010 4:35 pm
I cant tell I have standard OS, carbon, and normal. All pretty much point where I tell them to and dont fail under my rigorous riding style.
I cant tell between QR and maxle either for stiffness
Posted : 14/09/2010 4:39 pm
When I was involved in motorcycle racing many years ago my technical manager used to say:
"Get a test rider who can feel every little change you make to the bike, and a racer who will go flat out on whatever bike you put him on"
Posted : 14/09/2010 4:43 pm
Carbon fibre components tend to have a higher "reflex" than aluminium ones o a similar weight.
The carbon springs back faster (certainly noticeable on windsurf masts) which may equate to better damping.
Posted : 14/09/2010 4:46 pm
such as ?
My experience of STW is that it does not matter what anyone says most on here are of fixed opinions, so think what you like. I'm happy that whatever you want to believe or have faith in is what you have chosen so that is great.
I have some q's and a's (mostly aimed at [s]doubting thomas's[/s] SFB n TJ)
1) Can you feel trail buzz? Can you feel a change in road surface through your handlebars? Yes and yes. So small movements of 0.6mm or more will be easy to feel. If the answer is no to any of these then you will not benefit from incremental increases in stiffness so do not waste your money on OS bars/stems.
2) If you want your bike to go in a certain direction it pays if its pointing where you hoped, or if there is any flex which would lead to delay in how fast it gets to where you point it then if that is minimized then it will aid your control. Its all about precision. This is proven by faster and faster times in car/motorcycle/mtb/rollerskate races as chassis stiffness has increased.
3) Resonance - the stiffer a part is the amplitude of any resonant vibrations will be reduced for a given force input. (This is not he same as trail buzz which a stiffer part will make you feel more of, if you can feel it. Less resonance = more controlas its going where you want most of the time, not once every resonant cycle.
Posted : 14/09/2010 4:57 pm
Toys - you miusunderstand me.
I am sure OS bars are stiffer. I simply don't believe that makes any significant difference.
You might be able to feel it - I doubt it but its possible
[b]1) Can you feel trail buzz?[/b] yes - but this is irrelevant to steering inputs.
2) [b]If you want your bike to go in a certain direction it pays if its pointing where you hoped, ......... car/motorcycle/mtb/rollerskate races as chassis stiffness has increased.[/b]
Actually motorcycle frames are now built to flex - too rigid is not helpful. The magnitude of the loadings in steering inputs are so low that I don't believe flex is significant IN STEERING INPUTS
[b]
Resonance [/b]
Stiff may decrease amplitude but what relevance is thais to steering?
c
al - once again you simply fail to see my point then slag me off because of your misunderstanding of the basic point. perhaps once in a while you might believe you can misunderstand
As you are rather hard of thinking I say again
I do believe that steering inputs are of the magnitude that any flex they generate in the bars and stem is insignificant compared to other forces and flex at work.
I ask you again - what other issues is it about?
Posted : 14/09/2010 5:10 pm
you misunderstand, on this topic I've only seen unsubstantiated conjecture about why stiffer bars might be better. I'm perfectly willing to accept it given a measurable improvements
I don't ride on the road, so that isn't a useful criterion
do you understand how steering works ? You apply an input and see what happens, depending on the instantaneous conditions, and modulate your input to get the desired result. For a start, you don't point the bars, and to turn right you push them left (except when nearly stationary)...
resonance in the entire steering system perhaps, which is quite different to the bars themselves
Posted : 14/09/2010 5:14 pm
simonfbarnes - Member
Oh FFS. Note "relative to bars". Stiffer bars will...oh I give up. You do well at coming across as a pedantic prick.
If I understand you (I'm not really sure what you mean) I think I agree.
There are other forces like heaving on the bars while out of the saddle, pushing into corners etc and the one I have mentioned above.
I'm not saying my OS bars make me significantly faster or more in control, it just feels better, and that's enough for me, rather then winning pointless internet arguments.
Posted : 14/09/2010 5:23 pm
wayhay - you finally understand the point. Miracles!
Different rather than better? Remember some folk like carbon bars for their increased flex.
I'd bet you a tenner that you couldn't tell a difference back to back anyway.
Posted : 14/09/2010 5:31 pm
What he said, it makes no odds what deflection there is under normal steering inputs, but if the front end feels loose and wobbly you're not particularly inspired to push your limits (or the bikes).
In the same way I went from manitou minutes to magura menja's. The minutes never broke (structuraly) and WhatsHisName won multiple 4x world cups and world championships riding them, but the magura's are much stiffer, and my riding is much better as a result!
Posted : 14/09/2010 5:34 pm
tinas
Indeed. Flex in forks is far more significant and easy to see. a fork is a much less rigid structure than a handlebar.
Try holding the wheel between your legs and twisting the bars and see where the flex is visible - loads in the fork, some in the wheel, none in the bars or stem.
Posted : 14/09/2010 5:39 pm
pedantic ?? I cannot work out what your statement means, unless you mean that, if the bars get stiffer, the frame will appear to be more flexible in comparision ? The frame and bars are different components, and the stiffness of one does not influence the stiffness of the other. As far as I can work out, 'relative stiffness' is a useless concept.
but unless you do a double blind test, you cannot know if this isn't just expectation
Posted : 14/09/2010 5:44 pm
and probably even more in the tyre in actual use 🙂
Posted : 14/09/2010 5:45 pm
Has anyone mentioned relative stiffness other than you?
OK I'll spell it out:
Twisting the back wheel relative to the bars, a stiffer handlebar will give less flex overall.
I said "better".
We will never know - neither of us can prove the other wrong, but it's a fact that os bars are stiffer, and many many things like this on bikes (eg lighter wheels) can easily be felt but can barely be measured.
Posted : 14/09/2010 6:01 pm
Al give up trying to enlighten them. I got bored a while back, it really does not even matter, unless you are paid loads of money its just pointless trying to educate those who do not want to be educated.
Posted : 14/09/2010 6:07 pm
Quite right, they'll always argue stuff they have little or no experience of.
Posted : 14/09/2010 6:10 pm
Oh toys - don't be so offensive! I am listening and sometimes you even have things worth listening to.
We are at cross purposes slightly however but both you and Al are so arrogant and sure of yourselves that you fail believe that sometimes you could misunderstand or be mistaken - as in the "fact" about stiff racing motorcycles when nowadays building in flex is considered critical.
I agree OS bars are stiffer, I agree that you will be alble to feel this in pulling on the bars, I disagree that this is at all relevant to steering as steering inputs are so low in relation to the forces that are needed to produce the flex.
Al - its also clear from this and previous discussions that actually you have no idea on the dynamics of steering.
Posted : 14/09/2010 6:12 pm
hmm, you might as well say "Twisting the Eiffel Tower relative to the bars, a stiffer handlebar will give less flex overall.". Yes if it's stiffer it will flex less. Tautology.
viz: 'Oh FFS. Note "relative to bars".'
I contend that lighter wheels can be measured with a scale.
I'm happy to accept that, I'm only asking if it matters.
I would love to be enlightened, but handwaving gobbledygook will not achieve it 🙁
Posted : 14/09/2010 6:20 pm
I agree OS bars are stiffer, I agree that you will be alble to feel this in pulling on the bars, I disagree that this is at all relevant to steering as [b]steering inputs are so low in relation to the forces that are needed to produce the flex.[/b]
TJ I agree with the highlighted bit - it's other areas that I say os bars affect beneficially.
SFB I started typing but gave up, I just CBA engaging with you.
Posted : 14/09/2010 7:07 pm
Al - and thats where you missed my point as I never disagreed with you on that - I was only ever talking about steering. I never even mentioned other aspects.
Folk claim steering is significantly better with OS bars and with a stronger stem. I say this is emperors new clothes.
Posted : 14/09/2010 7:11 pm
as always 🙂
IMO there's a great difference between enlightenment and indoctrination, one involves information and understanding, the other disinformation and credulity. One uses one's critical faculties to tell them apart.
Posted : 14/09/2010 7:43 pm
Here's a thought experiment - imagine a range of handlebar materials/stiffnesses from rubber to diamond monofilament composite. In terms of steerability, it will go from:
useless
bad
adequate for normal riders
perfect for fussy riders
far too expensive to be sensible
now, setting aside personal preferences, one could experiment to find out how much stiffness is required for controlled steering in the most arduous conditions, and beyond this, adding more stiffness would just make the bars more expensive with no improvement in riding. What we don't know is, where current bars lie on this scale. What we do know is that asking riders what they feel about the matter does not constitute a measurement.
As far as I'm concerned, toughness is more important, I want to be able to crash them repeatedly and either be unaffected or bend so obviously I know they're scrap!
Posted : 15/09/2010 4:40 pm
 Keef
probably betterer for 'big boned' clumsey types......
Posted : 15/09/2010 5:09 pm
OK, but that begs the question "How is the increased stiffness achieved ?" if the bars are made OS but retain the same weight, they will be stiffer but more prone to crash damage, and a larger rider will produce greater impact forces...
Posted : 15/09/2010 5:20 pm
 Keef
Dunno,only use Jones bars meself.bit flexy,but suit me sir.....
Posted : 15/09/2010 5:52 pm
Yet more guff!
Posted : 15/09/2010 5:57 pm
 Keef
certainly couldn't be another manufacturers gimmick,like-
'we need to sell more bars'
'but how ?everyone's got bars'
'easy,tell em they need fat bars'
no way,couldn't happen,oh no,definately not ! move along now punters.....
Posted : 15/09/2010 6:01 pm
Due to a power****ing addiction, I like standard on the left, and OS on the right....
Posted : 15/09/2010 6:18 pm
 Keef
still the same old Will then........
Posted : 15/09/2010 9:14 pm
Yet more guff!
go on then, if I'm wrong, what [b]is[/b] the relationship ?
BTW, I meant assuming the same material...
Posted : 15/09/2010 10:14 pm
Page 2 / 3
