Is any amount of pi...
[Closed] Is any amount of pivot play too much pivot play?
 bubs
I have just built up a second hand Santa Cruz 5010 cc (eBay bargin) which has a tiny amount of play in the lower linkages.  Is this something that needs fixing fast or can I just get a grease gun and try fresh grease and re-tightening?  Is some movement expected with vpp?
Posted : 19/05/2018 11:11 pm
Movement which way?
Posted : 19/05/2018 11:14 pm
It should move freely in the intended direction, but if there’s any sideways movement I’d want that looked at PDQ like.
it’s probably only bearings, and they won’t be much.
Posted : 19/05/2018 11:19 pm
 bubs
Everything moves freely and as it should but if I hold it by the saddle I can feel some movement/play/looseness.
Are the bearings a specialist job or should any lbs be able to sort them?
Posted : 19/05/2018 11:26 pm
Lifting the seat?
Lift it from the top tube to check it's not the post.
After that check the shock bushes
Bearings are best done with the nice tools but can be done by anyone who knows what they are doing
Posted : 19/05/2018 11:28 pm
I don't own that bike but they shouldn't be difficult to obtain and yes, and half decent lbs should be able to fit them. It's a DIY job too, if so inclined.
You might find the rest of the bearings could be dry even if no movement is apparent.
Posted : 19/05/2018 11:30 pm
"After that check the shock bushes"
What exactly are shock bushes?  I've never really understood.
Posted : 19/05/2018 11:44 pm
Definitely not play in dropper/saddle?
Shock bushing first port of call, if the plays there it's cheapest & easiest fix (I know this after replacing bearings & only after realising it was bushing!)
Posted : 19/05/2018 11:45 pm
The hardware in the ends of the shock you have a bush which sits inside and then the hardware goes along side it
Posted : 19/05/2018 11:46 pm
 bubs
Definitely in the linkage bearings unfortunately.
Posted : 19/05/2018 11:53 pm
In that case just get it down the LBS
Posted : 19/05/2018 11:58 pm
