HT2 Bearing removal...
[Closed] HT2 Bearing removal tool?
17 Users
Who makes the cheapest decent one?
Thanks! 🙂
Posted : 11/01/2011 4:29 pm
got one you can borrow if any use?
got it from betd
Posted : 11/01/2011 4:31 pm
I went for a park tools in the end 4 years ago and still sweet 🙂
£17.58 - JE James
However the cheapest decent one is the ice toolz or equivalent one:
£5.95 @ merlin and is double sided
Posted : 11/01/2011 4:34 pm
Ahh. I wasn't very clear was I? 😳
I meant the thing to take the actual bearing out of the cups 🙂
Ralph, how much is the BETD one, can't find it on the website?
Posted : 11/01/2011 4:36 pm
Nope - no probs - I was wondering why you didn't have one PP 🙂
Posted : 11/01/2011 4:38 pm
Foxy, I have tools coming out of my ears at home, just not this one!
(I do like tools!)
Posted : 11/01/2011 4:39 pm
Me too - love tools too 🙂
Posted : 11/01/2011 4:40 pm
TBH I just use a hammer and screwdriver after warming the cups up a bit.
Posted : 11/01/2011 4:42 pm
Remind me not to buy a bike of you bigyinn 😉
Posted : 11/01/2011 4:46 pm
Nooooo
Just cut a washer(slightly smaller than bearing outer) in half, file the sharp edges down, insert one at a time behind the bearing and push out with two sockets - one through the bearing onto the washer and one bigger than the bearing outer braced on the BB body.
Posted : 11/01/2011 4:49 pm
 D0NK
BETD used to do one, raceface were supposed to be releasing one, I was looking a while ago and couldn't find one. Been trying to talk the guys in our workshop to make one for me, only need a threaded bar and some correctly shaped ali bits I think. No luck so far.
Posted : 11/01/2011 4:50 pm
The enduro one from BETD is about £120.Bearing mf do one via madison thats about the same price.
Posted : 11/01/2011 4:51 pm
Hmm. Good idea!
Posted : 11/01/2011 4:52 pm
Ahh. I'll try something else at that price!
Posted : 11/01/2011 4:53 pm
Posted : 11/01/2011 4:54 pm
I got one! Bought it off here and haven't needed to use it yet.
I suspect you want your own rather than a borrow though..?
BETD, do make one its only £20, its not on their website, you have to call them. I got one.. great tool... note they give you one free if you get x5 sets of the enduro bearings...
give them a call... if not, post your cups down to me and I will swap the bearings out for ya. Worth getting the tool tho IMO
there is this one but it is uber expensive... circa $200
[url= http://www.endurobearings.com/bicycle.html ]http://www.endurobearings.com/bicycle.html[/url] the brt-001 -edit- the one Rorschach posted
Posted : 11/01/2011 4:57 pm
Tim Johnson at Sideways cycles used to have them but they weren't cheap, £40 or £50 I think. I think that they were Phil Wood ones so obviously very good but explains the price.
http://www.sidewayscycles.co.uk/
Posted : 11/01/2011 4:59 pm
Raceface do do one, I have one upstairs. It's about £50, but I don't know where it came from.
Posted : 11/01/2011 5:02 pm
pricey but not quite [url= http://www.enduroforkseals.com/id114.html ]$200[/url]
the phil woods is [url= http://www.aspirevelotech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=RXBRAK&Category_Code=PWLUBETOOLS ]$127[/url]
Posted : 11/01/2011 5:03 pm
out off stock on the [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=40434 ]raceface[/url]
Posted : 11/01/2011 5:06 pm
£20 PP from betd
Posted : 11/01/2011 5:40 pm
Ralph, cheers mate I'll ring them I think 🙂
Posted : 11/01/2011 5:44 pm
I've got the Enduro one. It's lurve-ly
Posted : 11/01/2011 5:52 pm
I just use a couple of sockets and an extension bar, knoing them out theres no problem doing it over the inner race, knocking them in just find a socket that presses on the outer or just put the bearign on a wooden worktop, cup over it, hammer them together and finish off with a drift/screwdriver.
Posted : 11/01/2011 6:17 pm
i found "steaming" the cups helps with removing the top hats without breaking the very brittle plastic.
Posted : 11/01/2011 6:34 pm
Racing-ralph, have you got any pics of the betd one?
Posted : 11/01/2011 6:38 pm
its not a usual thing i photograph to be honest
Posted : 11/01/2011 6:47 pm
😛 yer sorry, i'm just going to try and make my own on a lathe, just wanted to see the design!
Posted : 11/01/2011 6:57 pm
Posted : 11/01/2011 7:39 pm
foxyrider - Member
Whats the problem, the old bearings are going in the bin, the new ones will get pressed in using a sash clamp (larger adjustable version of a G clamp) using sockets on the outer bearing race.
Posted : 12/01/2011 12:05 pm
Aren't BETD doing an offer when you can send your cups to them and they'll replace the bearings with better ones free of charge?
Posted : 12/01/2011 12:31 pm
If BETD are fitting enduro ones for you then I'd pass, mine were rotten, lasted less time than a Deore BB.
Basically, if it's an angled bearing (ie the inner race can easily come out of the outer one, like an Acros Clockworx, then you might need a proper tool. But for Shimano, the correct tool is a hammer, no reason to get any more complicated- whacking the inner race will take the whole bearing out.
Posted : 12/01/2011 1:58 pm
Thank you, although, you'll incurr foxriders wrath also now!
Posted : 12/01/2011 3:41 pm
