Hi,
My RP23 sags very slowly when in propedal when just sat on the bike.... Havning not ridden my full sus for 2 months, i can't quite rememeber if this was normal!
Should the shock compress slowly when in propedal? i thought there shouldn't be any sag when propedal is on?
Thanks
Ricks
There will be some sag, can't comment on speed, but your seals won't have gone in 2 months' inactivity.
sounds ok, if the seals are gone you will get oil leaking/air loss
do you have a oily shaft 😆
EDIT fnar fnar
It appears to sag almost to the same length as when in full travel, only it takes a while to get there!
The shock's had about 8 months use now... races, trails, AM stuff....
do you have a oily shaft?
Nope, mine's dry as a bone.
your ok then 😉
What about hte Propedal circuit? could that have gotten screwed?
no, i think it will be ok, pp just tightens the first 1/4-1/3 of the stroke to eliminate bob but dos'nt lock it out thats why you set sag with it off
i have a rpl and set to pp it do's the same as you describe but set to lock it locks at the top of the travel with no sag at all
i think its ok
