My bike is pretty old, but apart from the v-brakes I like it a lot and don't really want to sell/scrap it just to get better brakes. It has frame and fork mounts for discs so just need wheels and brakes.
Would it be possible for less than £300? Much more than that and I might start looking at a used bike instead.
Are your shifters sperate from your brake levers or are they combined into one unit?
I'd guess it should be possible for under £250 fairly easily new with handbuilt wheels. Obviously used it'd be less
Have a look on merlin cycles, looks like it might be possible for around £212+ plus postage
What do the frame/fork mounts look like?
[img]
[/img]
IS mount or post mount (your frame I'd guess will be IS mount?)
They're combined shifters/brakes, so new shifters too then, hadn't thought of that. Maybe still under £300 for new bits though?
How many gears on the rear?
Secondhand parts easily under £300. I paid around £50 an end for hope minis, £50 a wheel for basic disc wheels
I bought a sey of XT discs for £130 s/h and a set of Hope hoops for £140 again s/h off this site (or could have been bike radar). All was as new and works briliantly. Cheaper ranges (ie SLX) would of course be cheaper still s/h. Trawl those classifieds!
OK, just been to check the bike - I have 8 gears (thought it was 9, had to count 3 times to be convinced!). Fork (tora) has post mounts. Frame looks like the IS mount (2 holes on a welded plate, basically).
[url= http://www.merlincycles.co.uk/Bike+Shop/MTB++Parts/Brakes/Disc+Brake+Kits/SLX+Disc+Brakes++LXACE+17+Wheels_SLX-KIT1.htm ]Thiskit would leave you plenty for new shifters also.[/url]
Aha, that looks just right, thanks for the help guys, I started looking myself but was a bit overwhelmed by choice and not knowing what I was looking for exactly. Ta!
Remember to register your e-mail if you buy from Merlin and you'll get 10% "VIP discount" on most stuff 😀
This does mean that the only original bits of my bike will be the frame, stem and bars... And it's only a Hardrock frame.... but it fits and I like it so what the hell
Cool, thanks hilldodger!
Yay, Triggers Broom Bike 🙂
You can keep your combined brake/shifter levers if you go cable Avid BB7s, and save a packet if you rebuild your own wheels.
TuckerUK +1
BB7s are rather good.
