How many links to r...
[Closed] How many links to run Compact and 11-32 ??
I'm just about to go to Nice for a week of riding and after a poor year, am thinking I need more help. I have a 10 speed rear mech with long cage, an 11-32 cassette and I need a new chain, do I need a 120 linker or would a 114 link work ??
So its a 50/38 compact and an 11/32 cassette on a road frame with fairly short stays.
Any ideas ??
Posted : 17/09/2012 8:46 am
No, How long is a standard shimano chain, that works 50-27. You need enough to go round the two biggest rings+1 link as a general rule. If this isn't enough then you just need to remember not to shift into big big as you'll break something!
Sheldonbrown have any answers?
Posted : 17/09/2012 9:07 am
only ever bought 114 and always taken links out...
Posted : 17/09/2012 9:10 am
Interested in the answer to this myself, since I am about to do a similar thing! I was under the impression though that a long cage road mech is equivalent to a med cage MTB mech and couldn't take a cassette larger than 30 teeth. So to add a larger cassette you basically need to use a 9-spd MTB long cage mech (which has the same pull ratio as road 10-spd)? Although to be fair I could be talking out of my arse as I really don't know? 😆
Posted : 17/09/2012 9:19 am
My Planet-X Pro Carbon has a SRAM WiFli kit on it 12/32 with a 50/38 compact
That uses a 109 [+ powerlink] link chain
Posted : 17/09/2012 9:26 am
two biggest rings+1
I thought it was 2-3 links extra.
Posted : 17/09/2012 9:48 am
I'm also interested in this. I need to lower the gearing on my Hybrid (currently 11-26 9-speed cassette and 34x50 FSA chainset) as run out of low gears on steep climbs.
Rear mech is SRAM X5.
Swapping the whole lot out to 10-speed is not an option, and don't want to spend £100's...
Any reason I can't fit a shimano HG50 12-27 cassette? will I notice any real difference from 1 more tooth?
What are my options? (other than greater fitness, which is coming)
Posted : 17/09/2012 9:58 am
