So, the Solaris max is available now but how long before I can get a Soul Max? Thats what I really want.
If you haven't finished the design yet Cotic, this is what I'd like ๐
Decent tire clearance for up to 2.8s (but I'll be running 2.5s on 35mm rims)
A 650mm ETT on the 19 inch large
65 degree head angle
130mm head tube on the large
Boost rear
Don't taper the seat and chain stays towards the dropouts keep them fat all the way it looks better.
Finally I'll have one in Coca Cola red please, and if you could make them available before the summer that would be brilliant.
Er... what size wheel would that be then?
27.5 Wheels just like the current Soul.
I'd just like to run biggish tires and have a longer toptube.
Solaris Max = Stanton Sherpa next gen
Soul Max = Stanton Slackline next gen
Isn't the Solaris Max B+?
Tires up to 2.8 are only plus in width not diameter and should be matched with a 27.5 frame with a suitable bottom bracket height.
The Solaris Max has a 29er BB height so using it with 2.5-2.8 will make it a bit low. Its intended for 27.5+ 3.0 which are closer in diameter to 29.
I guess the Pace rc127+ is aimed at 2.6 tires and it has a 56mm BB drop which is more than the Solaris Max which is 52mm
My Sonder Transmitter has a BB drop of 42mm which feels quiet low with 2.8s. If I put the same wheels on a solaris max that puts my cranks 10mm lower still
A Slackline next gen is 48mm so thats actually pretty close to the Solaris Max though.
Maybe I wouldn't notice
