How does one work o...
[Closed] How does one work out gear ratios?
[#1881515]
I have a 32-12 currently but need to use a 16, 17 or 18 when I singlespeed the commute. Is there a way to work out the equivalent needed chainring?
You're all awesome.
Posted : 10/08/2010 7:28 pm
gear inch calculator
[url= http://software.bareknucklebrigade.com/rabbit.applet.html ]http://software.bareknucklebrigade.com/rabbit.applet.html[/url]
Posted : 10/08/2010 7:34 pm
Yes; gear ratio, in inches, = chainring teeth number / rear sprocket number x 27
so currently you are running a 32/12 x 27 gear, ie 72 "; if you opt for a 16t sprocket then you need a 42.67 tooth ring, lets say 42T for simplicity; 17 T and you need a 45. 33, ie 45 T....... 😐
Posted : 10/08/2010 7:39 pm
I check Sheldon - anything techy and complicated, Sheldon's the MAN
Posted : 10/08/2010 7:40 pm
Why do you need an easier gear on teh commute?
How are you running a 12T rear cog if you don't mind me askin?
Posted : 10/08/2010 7:42 pm
gusset do a 12t SS cog
Posted : 10/08/2010 7:52 pm
