Horizontal dropouts
[Closed] Horizontal dropouts
 dday
This may be obvious: I'm converting an old on-one inbred from singlespeed to geared. It has horizontal dropouts. Do I need to do anything before dropping the cassette in? Presumably the hub will just sit snug up against the frame, and I can adjust the chainlength for the right tension. Or do I need some kind of conversion part? The frame already has the derailleur mount.
Obviously you would need a conversion from vertical to horizontal if going singlespeed, but I want to go geared on horizontal dropouts.
D
Posted : 09/01/2016 5:52 pm
Yup, nope, bung the wheel in to the bottom of the slot, the mech will take care of chain tension assuming you set the length the usual way with derailleurs.
Posted : 09/01/2016 5:57 pm
And if the tyre touches the seat tube just use a chain tug all I needed with the same frame but with stupid sized tyres I thought I was being clever called a fool by everyone 6 years later and it's all the rage +tyres
Posted : 09/01/2016 6:29 pm
The horizontal on one dropouts with hanger were the best. Not sure why other companies don't use them on ridgid frames.
Posted : 09/01/2016 6:47 pm
Harder to remove the wheel if you get a puncture.
Posted : 09/01/2016 6:55 pm
