Hope S/S hub issues
[Closed] Hope S/S hub issues
6 Users
just been out for my first ride and when freewheeling the wheel drags big time,
I have checked the bearings and all is okay, pulled off the cassette all runs smooth even when I refit the cassette body, but it goes tight/ stiff when I put the axel cap on
any ideas
pweeze
Posted : 07/04/2010 8:25 pm
It could be missing the spacer that sits inbetween the inner freehub bearing and the hub bearing
Posted : 07/04/2010 9:49 pm
 69er
That is the most likely reason.
Posted : 07/04/2010 9:53 pm
The spacer is there and I have just replaced the cassette body bearings and it is still the same and when coasting you can feel the wheel trying to drive the pedals
Is it dragging because of the 4 pawls and I am not used to it??
Or am I being daft but I have never had this before
Posted : 15/04/2010 7:05 pm
Some hope hubs needs a bit of time for the seals to free up a little.
Posted : 15/04/2010 7:58 pm
mine does have some drag, but not noticeable when riding. I just rebuilt mine after discovering some play in it and after sticking it all back together it still drags but not as bad and that is mostly due to fresh grease.
Posted : 15/04/2010 8:33 pm
If the spacer is definitely there, then make sure that the seal between the freehub body and hub is properly seated. If it isn't, it causes loads of drag. You should be able to press it in by hand and it will snap into place.
Posted : 15/04/2010 9:43 pm
The spacer is definatly there but I did not realise the seal had to be pressed in
I will try it tomorrow thanks for that
Posted : 15/04/2010 9:48 pm
Aidan
Sorted
I owe you a beer thank you it was the seal and it did locate with a snap when I pushed it in
Posted : 16/04/2010 9:19 pm
Ha - I'll turn up in your local one day 🙂
Glad it's sorted.
Posted : 16/04/2010 9:46 pm
