Hope Pro2 front hub...
[Closed] Hope Pro2 front hub question
Currently running my Pro2 front for a 15mm axle but can you replace the spacers to enable you run 20mm axle forks? I'm guessing you can as they're just spacers.
Posted : 10/07/2011 12:34 pm
Yep. That's what I'm using. ๐Ÿ™‚
Just needs new spacers
Posted : 10/07/2011 12:36 pm
Cheers. It's ok I'm faffing over my new frame and the forks on it. I've got some Float RLC 15mm forks which are 140mm travel and my new frame, a Turner 5 Spot DW Link has 150-160mm forks being recommended so I thought of maybe getting some 160mm Floats. But I've checked the axle to crown length on my current Floats and it's the same as the 150mm Floats so I might be worrying for nothing.
Posted : 10/07/2011 12:43 pm
