Hope Pro II freehub...
[Closed] Hope Pro II freehub gone quiet
19 Users
The nice clickety-whizz noise of my Hope Pro II freehub seemed to be conspicuous by its absence today. It still works perfectly but just sounds like a 'normal' hub now. Does it just need a clean?
It's about 6 months old and hasn't had any attention since new.
Posted : 06/04/2010 6:04 pm
"I don't like it, its too damn quiet..." 😀
there is something a bit disconcerting about changes in freehub noise, can only think the grease might have somehow got stickier/thicker.
Posted : 06/04/2010 6:06 pm
 momo
They're normally quieter after being serviced! I know my freshly re-greased bulb is running very quietly at the moment and gets louder as the grease breaks down.
Posted : 06/04/2010 6:07 pm
It probly needs new [url= http://www.ukbikestore.co.uk/product/176/hub515/hope-pro-2-pawl-springs-set-of-4.html ]pawl[/url] springs when they wear they don't flick back the teeth to hub with such power.
Check all your leaf springs are in one piece (after a soggy winter they can disintegrate).
Posted : 06/04/2010 6:09 pm
Philden beat me to it! 🙂
Posted : 06/04/2010 6:10 pm
New pawl springs after only 6 months? It's probably only done a few hundred miles.
Just ordered some for myself
Mine have only lasted about six months they are very flimsey.
Posted : 06/04/2010 6:12 pm
Mine were disintegrating a lot, then I stopped using Muc-off and they've stayed in one piece ever since.
Posted : 06/04/2010 6:13 pm
Well I think I can manage £3 so I'll get some new ones. As it's only recently gone quiet can I assume I'm ok to ride for a while without it dying on me?
Posted : 06/04/2010 6:14 pm
Ah - I do use Muc-off
Posted : 06/04/2010 6:15 pm
Posted : 06/04/2010 6:17 pm
Like you say its 3 quid why risk it?
Posted : 06/04/2010 6:18 pm
I mean is it going to die on me at the top of Snowdon on Friday if I haven't sorted it by then??!!
Is there a vid on the Hope site which covers this job?
Posted : 06/04/2010 6:19 pm
Yeah the Hope site will show you how to rebuild the whole rear hub should be ok i guess but that is a guess 😕
Posted : 06/04/2010 6:21 pm
Just like a Doodlebug - no problem as long as they're making a noise 😀
Posted : 06/04/2010 6:24 pm
I would kill for a silent hope hub. Actually, I'll have 2, one for me and one for ChrisL so that I don't spazz out completely every time he's riding behind me.
Posted : 06/04/2010 6:50 pm
I was actually disappointed with my pro2, thought it was going to be much louder!
Posted : 06/04/2010 7:34 pm
saw a pro 2 on ebay once.
Advert said "Awesome Clicky noise!"
Posted : 06/04/2010 7:41 pm
my new silver set r quiet...but my old pro1 were loud as hell.
Posted : 06/04/2010 7:44 pm
 Amos
Remove cassette
twist off free hub body,
Clean ALL the grease out using tooth brush and brake cleaner or similar,
Lubricate with wet chain lube,
Rebuild
hmmmmmmmmmm Noisy free wheel, no need for a bell either! 😆
Posted : 06/04/2010 7:47 pm
Are the pawls and springs the same as in the old XC hubs? I remember almost launching my old hub XC hub through the window after 30 minutes of faffing trying to get them all to stay in place while I put the freehub back on. Not yet needed to service my Pro IIs but want to know what I'll be in for.
Posted : 06/04/2010 7:56 pm
 jimw
No, it is really very simple, the springs stay in place in the body and you just twist it back in. Video on Hope website- mostly about the bearings but shows how to put back together
Posted : 06/04/2010 8:03 pm
 Amos
Very easy to service, a seal holds the free hub body on and is really easy to take apart and rebuild with no specific tools required, you can get the seals back if you have strong fingers. Hope website has a tutorial and it's easier than they describe Honestly
[url= http://www.hopegb.com/page_mep_force_37.html ]Hope tutorial Linky[/url]
Posted : 06/04/2010 8:05 pm
i would look inside and fast as my freewheel went quiet and it took a couple of rides before i had a look in there.One of the bearings had collapsed and the alloy body was cracked as the freehub was driving on the ring instead of the pawls.It was scrapped and i needed a complete new freehub.This was no fault other than myself not checking why it had went quiet
Posted : 06/04/2010 8:11 pm
I hate to say this but my 6yo Hope XC rear hub slipped into stealth mode about 4 years ago. I has never worried me... until now......
Posted : 06/04/2010 8:34 pm
Pro3s are even louder 😯
Posted : 06/04/2010 8:39 pm
 dale
have a look better 15 mins at home than a long walk home. if the grease is washed away or dry around the springs they wont last long
Posted : 06/04/2010 9:30 pm
Cut down mini zip ties are more durable than the metal pawl springs IME. After changing metal springs twice I swapped to zip ties and they've been fine ever since
Posted : 06/04/2010 10:00 pm
All sorted. No broken springs just lots of muck in there. Cleaned and rebuilt with a new set of springs anyway 🙂
Posted : 07/04/2010 9:26 pm
My Pro II went quiet because 3 of the 4 leaf springs had broken. The fourth one broke when I took the hub apart to service it. So while Northwind may not like the noise from my hub when I'm riding behind him, to me it's a good sign that the thing is not about to fail on me.
JImmAwelon, the springs in Hope XC freehubs are completely different to those in Pro IIs and I suspect they're much less likely to break. They are however far more likely to go everywhere when you disassemble the hub, so take care if you do!
Posted : 07/04/2010 9:41 pm
