Hi STW'ers
Just a quick question. I want to top up the fluid in the reservoir on my Hope Mono Mini's and it says on the cap only use Dot 4 or 5.1. Now I know you shouldnt mix the two fluids but which type of fluid do Hope fit as standard from the factory on these brakes. If it helps the date stamped on the reservoir is 06/04.
Thanks
Matt
Dot 5.1, I reckon. S'what I've used to do mine, and I haven't died yet.
Hello Rudeboy
How are you keeping? Your Big Smoke ride out sounded cool today. Thanks for the help.
Take care.
Matt
Hope fit 5.1..
5.1 in their bleed kits, only real difference is higher number equals higher boiling point, which you'll lower if you mix 4 with it.
I mix with no problem...
