Hope Master Cylinde...
[Closed] Hope Master Cylinder Cap screw rounded - source?
7 Users
Honest gov, I was hardly breathing on it. Can not be the first to do this and I am stuggling to find a source of the bolts, (yet to ring Hope) CRC have whole thing but out of stock.
Current thoughts are to gently hacksaw in a cut and convert to screwdriver. Suggestions?
Posted : 09/04/2010 6:38 am
Any Hope dealer should have the latest Torx fittings as spares, the old ones round out easily as you've found. A needle file's a bit more controllable than a hacksaw if you're bothered about marking the cap when you slot the screw.Drilling the head off will usually leave enough of a stub to grip with good pointed molegrips, but i'd use that as a last resort.
Posted : 09/04/2010 6:51 am
Jim at OnePlanet adventure (Llandegla) sorted me out with a couple of spares from the service box, so any Hope dealer should be able to sort you out.
Posted : 09/04/2010 10:27 am
Just email Hope, they're superb to deal with.
Posted : 09/04/2010 10:58 am
Hope should be your first port of call, they almost always send out parts FOC for stuff like that, they're brilliant.
Posted : 09/04/2010 11:17 am
I've just had exactly the same problem. Chain Reaction have them in stock at the moment [url=http://] http://www.chainreactioncycles.com/Models.aspx?ModelID=3265 [/url] but I'd agree with speaking to Hope first as they'll probably send you some FOC. As has been said, replacements are Torx fitting.
If it helps, I got the old ones out by cutting a slot in the top of each screw head with a junior hacksaw and then puting a wide but fine tipped screwdriver in...
Posted : 09/04/2010 11:23 am
Cut a slot with a hacksaw works - if you put two blades in the hacksaw you get a wider slot. cover the lid with gaffa tape to help stop it getting marked. The screws only need to be nipped up very gently
Posted : 09/04/2010 11:55 am
