Hope Brake Question...
[Closed] Hope Brake Question - Just a quickie
3 Users
I have a M4 brake set currently running a set of 180mm discs (f&b)same as these:
Now could I use these 180mm rotors with the new series of Hope brakes that run on 183mm rotors like these:
I fancy a change/more adjust-ability re the brakes but don't fancy shelling out another £44 on rotors 3mm larger
Posted : 05/04/2010 6:12 pm
Seriously??
all that would happen is an extra 1.5mm of the pad surface would remain unused on the new system , you could probably remove 1mm of spacers if the brakes are on post mount to bring the calipers down to bite more of the rotor.
Posted : 05/04/2010 6:45 pm
 devs
The new rotors wont fit in the old calipers if they are ISO mount. Well, not until you take a wetstone to the outside of the rotor whilst it spins! Non issue going the other way.
Posted : 05/04/2010 6:48 pm
