homebrew degreaser.
[Closed] homebrew degreaser.
10 Users
I think degreaser from the LBS is rather expensive though it is good at what it does. Are there any homebrew versions people make and use themselves?
Posted : 02/07/2011 12:47 pm
I use white spirit for my chain.
Posted : 02/07/2011 6:23 pm
I normally use the wife's home made curry sauce. Cleans more than chains too. :mrgreen:
Posted : 02/07/2011 6:28 pm
 Olly
brush saver is good, but it is designed to eat plastic, so comes in a metal tin, should only be used in a glass jar, and shouldn't be put down the drain. (and don't take it within a million miles of your paint or laquer either)
eats EVERYTHING off the chain though 🙂 new chain ahoy!
Posted : 02/07/2011 6:44 pm
white spirit, diesel for a long soak. Kerosene is what is used in a proper degreasing bath.
buy one of these and you can just buy a gallon bottol for cheap nad it will last for ages.
http://www.machinemart.co.uk/shop/product/details/cw2d-bench-mounted-parts-washer/path/parts-washers-blast-cabinets
Posted : 02/07/2011 7:06 pm
Use dry lube; clean with warm water and Fairy liquid.
Posted : 02/07/2011 7:08 pm
^ but doesn't fairy liquid have salt in it? That can't be good.
Posted : 02/07/2011 7:16 pm
I like to use di-ethyl ether to degrease my chains, it makes the process so much more enjoyable (and flammable).
Posted : 02/07/2011 7:19 pm
i'm thinking something I can make at home and put in a spray bottle to clean stuff insitu plus I don't like soaking things!
Posted : 02/07/2011 7:41 pm
[i]^ but doesn't fairy liquid have salt in it? That can't be good.[/i]
Then you rinse it off... 🙄
Posted : 02/07/2011 7:47 pm
You're probably best off with a hydrocarbon solvent like those already mentioned, white spirit or kerosene etc. I've never degreased a chain in my life, but I imagine if you had a power link on it and just snapped it off and shook it in a jam jar of petrol that would do the trick.
You could try dichloromethane which is a superb solvent and used in a lot of degreasers, could probably get this from hardware stores. It's non-flammable, but quite volatile (bp 40 degrees IIRC) and probably not very good for you (no solvents are).
Posted : 02/07/2011 8:22 pm
Kerosene = heating oil, about the cheapest degreaser there is at about 40p per litre. Helps if you, a friendly neighbour, or a family member use heating oil obviously.
Posted : 02/07/2011 9:27 pm
DCM can also be used for extraction of psuedoephedrine if you need a sideline for paying for your bike habit.
Posted : 02/07/2011 9:39 pm
