Help with Shimano c...
[Closed] Help with Shimano compatability to XTR RD-M952
2 Users
Shimano XTR RD-M952 90mm Cage rear Mech is damaged.
Got one of these which is set up on a bike with 8 speed cassette and XTR triple at front.
As its damaged, are there any other 90mm length cage mechs as a suitable substitute, need to keep the triple but could change to 9 speed casstte at a pinch?
Thanks
Richard
Posted : 05/11/2013 1:48 pm
Any 9 speed mech will do it, and work fine with 8 speed transmission (the M952 was a 9 speed mech anyway).
90mm could be medium cage (GS) or long cage (SGS), I'd have a stab at SGS - but check the product code on the mech to be sure.
Posted : 05/11/2013 2:37 pm
Thanks Njee
SGS seems longer at 115mm but I will have a look at shadow type which may be shorter?
Richard
Posted : 05/11/2013 8:02 pm
The actual length is immaterial frankly. Any GS (if that's what you have) or SGS mech will work fine, as long as it's a 9 speed Shimano one.
Posted : 05/11/2013 9:25 pm
Thanks.
Posted : 05/11/2013 10:15 pm
