Help with setting u...
[Closed] Help with setting up front mech
3 Users
Got a yeti 575 and trying to set up front mech.
I have a shimano slx front mech and SRAM xo shifter.
It's a triple and the problem is I can get the gears to shift perfectly on the stand but as soon as I sit on the bike the shifting goes to pot!
Any suggestions?
Thanks
Richard
Posted : 18/04/2013 8:34 pm
Outer cable not long enough and getting stretched tight when the suspension is compressed? Easily done if the cable routing is under the BB in particular
Posted : 18/04/2013 8:39 pm
I did think that , the outer finishes athe bottom bracket, it's inner under the bb and up to the mech.
R
Posted : 18/04/2013 8:44 pm
Have you checked the height over the big ring?
Posted : 18/04/2013 8:49 pm
About 5mm
Richard
Posted : 18/04/2013 8:50 pm
I get an "R" and he gets a "Richard"?!!? I'm out.....
should only be 1-2mm gap iirc, although I still wouldn't expect to see that causing the issue.
Posted : 18/04/2013 8:56 pm
Legend you are a legend
Sorry about the r theipadisplayinup.
Richard
Posted : 18/04/2013 8:57 pm
Sag setting on rear shock seems to be the culprit, checked and set for my weight and now shifting perfectly. thanks for your help.
Richard
Posted : 19/04/2013 9:44 am
